[mpich-discuss] Problem using Mpich2 on Vista machines
    Larry Adams
    ladams at platform.com
    Wed Jun 24 16:10:34 CDT 2009
The problem you get with simply running hostname using mpiexec in Vista,
is that if you are not a "privileged" (aka Administrators Group) user,
you won't have the required access to run hostname due to the "new and
improved" security measures.  Be prepared for fun.  This is why I used
the:
mpiexec -hosts 1 myhost cmd /c hostname
It allows you to work around this issue.  If you run without it you will
receive an Error 5 Permission Denied on the execution node.  If you
inspect the permissions of the hostname.exe file, you will understand
why.
Larry Adams
Senior Systems Engineer
Platform Computing
Tele: (586) 510-0007
Cell: (586) 899-1138
Skype: TheWitness
  _____
[mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Jayesh Krishna
Sent: Wednesday, June 24, 2009 4:01 PM
To: 'Fairchild, Jack'
Cc: mpich-discuss at mcs.anl.gov
Subject: Re: [mpich-discuss] Problem using Mpich2 on Vista machines
# Is SMPD installed on all the machines (Does "smpd -status" show that
SMPD is running on all the machines)?
# Can you try specifying an ipaddress instead of a hostname while
running your job (mpiexec -n 2 -host IPADDRESS_OF_HOST hostname)?
Jayesh
  _____
[mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Fairchild, Jack
Sent: Wednesday, June 24, 2009 2:44 PM
Thanks for the quick response Larry.  Windows fire wall is off.  I can
ping the machines, and can access the machines through explorer.  The
pass phrases are all the same "behappy" and since it's all networked, my
login and passwords are the same.  Just in case, I did run the smpd
-register command to no avail.  We're attempting to work around the
problem now by cloning one of the working hard drives.
Jack Fairchild
[mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Larry Adams
Sent: Wednesday, June 24, 2009 3:37 PM
Jack,
Try the firewall first, you have to unblock the smpd service port.
Beyond that, you have to verify that smpd service is installed,  and if
it's another host, you will either have to register a pass phrase, or
your account on the execution node to be able to continue.  If your
password ever changes, you have to re-perform this step.
Larry Adams
Platform Computing
Skype: TheWitness
  _____
Sent: Wednesday, June 24, 2009 3:26 PM
Subject: [mpich-discuss] Problem using Mpich2 on Vista machines
I've debugged as far as I can:
Invoking the command: mpiexec -validate -host myhost  returns:
Aborting: connection to smpd rejected
Invoking mpiexec -file myfile  returns:
Aborting: unable to connect to myhost
Some background.
All computers are running Vista Ultimate.  The computers are connected
by a 100mbs LAN.  A few months ago, I set up 4 machines for this use.
They all still connect without issue.
At this point I need to add some more, but am getting these errors.  All
machines have smpd version 1.0.8.  I am an administrator on all
machines, and installed Mpich2 as the administrator.  UAC was turned off
and remains off, all known firewalls are also off.  A path variable to
the bin directory  was added.
I ran smpd -d and all of the parameters match those of the working
computers.
What am I missing here?  I appreciate your valuable time.
Jack Fairchild
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090624/1de69adc/attachment-0001.htm>
