[mpich-discuss] CPI test fails under Fedora 10
    peter_raeth at juno.com
    Tue Jun 23 15:45:34 CDT 2009
You shouldn't need to reinstall F10, just "yum install glibc-devel"
should do it if it's not installed.  "rpm -V glibc-devel" will verify
that all of the files in the package are installed correctly.
When you rebuild mpich2, please send us the c.txt and m.txt files
(described on page 3 of the installer's guide).
-d
Wanted to be sure I actually installed everything from F10. Finished that process and reinstalled source mpich2.
Attached is the console output when I tried to run "make test_barriers". Also attached are c.txt, m.txt, and mi.txt after the mpich2 install was finished. All the single-machine tests went well.
Best,
Peter.
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090623/f43a3eb5/attachment-0001.htm>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090623/f43a3eb5/attachment-0004.txt>
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090623/f43a3eb5/attachment-0005.txt>
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090623/f43a3eb5/attachment-0006.txt>
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090623/f43a3eb5/attachment-0007.txt>
