[mpich-discuss] CPI test fails under Fedora 10
    Darius Buntinas
    buntinas at mcs.anl.gov
    Tue Jun 23 14:47:31 CDT 2009
You shouldn't need to reinstall F10, just "yum install glibc-devel"
should do it if it's not installed.  "rpm -V glibc-devel" will verify
that all of the files in the package are installed correctly.
When you rebuild mpich2, please send us the c.txt and m.txt files
(described on page 3 of the installer's guide).
-d
On 06/23/2009 07:36 AM, peter_raeth at juno.com wrote:
> I'm not sure what happened there.  Was your mpich2 source tree
> configured before you tried this?  It needs to be.  Try it again, from a
> fresh source tree (remove the old one, and untar the tarball again).
> After you configure, try the steps listed below again.  You shouldn't
> need to modify anything or copy any files.
> pthreads should already be installed in f10 if you have compilers
> installed.  Do you have /usr/lib/libpthread.a?  It's part of the
> glibc-devel package.
> Will go through the F10 install again. But, I'd installed everything,
> including development.
> For MPICH2, had downloaded
> http://www.mcs.anl.gov/research/projects/mpich2/downloads/tarballs/1.1/mpich2-1.1.tar.gz and
> followed the steps in the installer's guide, pp 2-6, Steps 1-11. That
> process went well.
> Still no fix on the physical Ethernet damage but I am encouraging our IT
> folks to proceed as soon as possible.
> Best,
> Peter.
