[mpich-discuss] CPI test fails under Fedora 10
    peter_raeth at juno.com
    Tue Jun 23 07:36:24 CDT 2009
I'm not sure what happened there.  Was your mpich2 source tree
configured before you tried this?  It needs to be.  Try it again, from a
fresh source tree (remove the old one, and untar the tarball again).
After you configure, try the steps listed below again.  You shouldn't
need to modify anything or copy any files.
pthreads should already be installed in f10 if you have compilers
installed.  Do you have /usr/lib/libpthread.a?  It's part of the
glibc-devel package.
Will go through the F10 install again. But, I'd installed everything, including development.
For MPICH2, had downloaded http://www.mcs.anl.gov/research/projects/mpich2/downloads/tarballs/1.1/mpich2-1.1.tar.gz and followed the steps in the installer's guide, pp 2-6, Steps 1-11. That process went well.
Still no fix on the physical Ethernet damage but I am encouraging our IT folks to proceed as soon as possible.
Best,
Peter.
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090623/455ab0ce/attachment.htm>
