[mpich-discuss] No hang-up with MPICH2
    Ralph Butler
    rbutler at mtsu.edu
    Mon Jun 22 10:42:01 CDT 2009
On a linux cluster, I tried this which worked fine:
         nohup time mpiexec -l -machinefile tempmf -n 2 hostname < /
dev/null &
I also replaced hostname with "cat -" just to see if requiring stdin
made any difference.
Since I was using tcsh, I switched to sh to what happened.  It still
worked fine although
the output went into a file (nohup.out) instead of to stdout.
On Jun 22, 2009, at 8:07 AM, Marc wrote:
> Greetings MPICH users,
> I would like to run mpiexec with a SSH connection and be able to
> disconnect without stopping the job. That requires the "nohup"
> command.
> When I enter:
> nohup time mpiexec -machinefile mach2000 -n 2 ./program
> The output from nohup makes a huge file with errors:
> mpiexec_my_cluster (handle_stdin_input 1067): stdin problem; if pgm is
> run in background, redirect from /dev/null
> mpiexec_goos-cluster.emt.inrs.ca (handle_stdin_input 1068):     e.g.:
> mpiexec -n 4 a.out < /dev/null &
> I tried:
> nohup time mpiexec -machinefile mach2000 -n 2 ./program < /dev/null &
> But it does the same thing. What's the correct syntax?
> Best regards.
> Marc
