[mpich-discuss] No hang-up with MPICH2
    Marc
    levesqm at emt.inrs.ca
    Mon Jun 22 08:07:52 CDT 2009
Greetings MPICH users,
I would like to run mpiexec with a SSH connection and be able to
disconnect without stopping the job. That requires the "nohup" command.
When I enter:
nohup time mpiexec -machinefile mach2000 -n 2 ./program
The output from nohup makes a huge file with errors:
mpiexec_my_cluster (handle_stdin_input 1067): stdin problem; if pgm is
run in background, redirect from /dev/null
mpiexec_goos-cluster.emt.inrs.ca (handle_stdin_input 1068):     e.g.:
mpiexec -n 4 a.out < /dev/null &
I tried:
nohup time mpiexec -machinefile mach2000 -n 2 ./program < /dev/null &
But it does the same thing. What's the correct syntax?
Best regards.
Marc
