[mpich-discuss] CPI test fails under Fedora 10
    Pavan Balaji
    balaji at mcs.anl.gov
    Thu Jun 18 09:37:06 CDT 2009
> The two machines are not connected. They are stand-alone, set up that
> way to work on this issue. Both have Fedora 10. One used the build
> instructions in the MPICH2 installer guide. The other used the rpm. Both
> yield the same issue, invalid instruction when MPI_Init tries to
> execute. Something is wrong with code building, as compared to the same
> build process used under Fedora 9.
This is very weird. Can you try to use the compiler separately? The
following command will give you the internal compile options mpicc is using:
  shell$ mpicc -show
Can you send us the output for this, and also make sure the correct
compiler is being used, the compiler works fine (by trying out some
simple program), etc.?
  -- Pavan
Pavan Balaji
http://www.mcs.anl.gov/~balaji
