[mpich-discuss] CPI test fails under Fedora 10
    Pavan Balaji
    balaji at mcs.anl.gov
    Wed Jun 17 14:57:45 CDT 2009
>   Used mpich2-1.1 Fedora 10 rpm on one machine and the raw-source
> install on another. The results are the same when I try to run cpi or
> any other code that built and ran under Fedora 9.
The binary packages in Fedora and most other UNIX distributions use a
different configure options that the default ones in the release (they
use shared library builds). So, you can't mix them. You need to either
use the binary version on both machines or the source-code based compile
on both machines.
  -- Pavan
Pavan Balaji
http://www.mcs.anl.gov/~balaji
