[mpich-discuss] CPI test fails under Fedora 10
    Pavan Balaji
    balaji at mcs.anl.gov
    Wed Jun 17 13:36:44 CDT 2009
Does it work on one machine? Note that both machines should be able to
see the installed copy of MPICH2. So, you can either install it to a
volume that's shared by both machines, or install it independently on
each machine in the same location (e.g., /tmp or preferably a persistent
volume such as /home).
Btw, FC10 should have MPICH2 binaries in their repositories, so "yum
install" should work fine as well (though installing from source is
obviously the preferred method).
  -- Pavan
On 06/17/2009 01:28 PM, peter_raeth at juno.com wrote:
> Searched the archives on this one and could not find anything. But, I'll
> be it is something that is a pretty simple oversight on my part.
> In setting up a new Linux cluster I downloaded and installed Fedora 10.
> Disabled SELinux and the Firewall since the network is isolated.
> Downloaded and installed mpich2-1.1 source and followed the default
> build/install instructions in the v1.1 install guide through Step 8 /
> Page 4.
> Also ran "make testing" while in the tmp directory (Page 22).
> All "which" commands respond as expected.
> All of this went well.
> While in tmp/examples, ran ./cpi.   The result is an "illegal
> instruction" error upon the program's attempt to execute MPI_Init.
> The same thing happens on a network of two nodes set up via the Fedora
> 10 rpm.
> Can someone tell me what I am missing?
> Thanks,
> Peter.
Pavan Balaji
http://www.mcs.anl.gov/~balaji
