[mpich-discuss] For beginning MPI users...
Ganesh
ganesh at cs.utah.edu
Thu Feb 26 16:29:45 CST 2009
I am new to this group, and notice that many folks are learning how to
program in MPI. I have a small tip for them.
Once they get their code to compile (*), they may wish to try using ISP
which was announced in this list just recently. ISP is extremely easy to
use (its user manual shows the 2-3 commands you need - i.e. you do ispcc
instead of mpicc , and ispcc calls mpicc from within -- etc.)
Once you run even your simplest MPI programs using ISP, you can watch
all the possible send/receive matches etc. graphically. In fact, much
more than a debugger, it shows all possible interleavings, and for each
interleaving (execution possibility) it shows what send / receive
matches can occur. ISP's Java GUI has tool tips and you can also watch
the source lines using the source window. The source window has tabbed
and split views, and you can further see the communication matches
through color codes.
You may also place C "assert" statements within your code, and ISP will
check those assertions for all possible executions of your code. Finally
you may catch deadlocks and MPI object leaks. All this for doing "ispcc"
instead of "mpicc"
(see user manual at
http://www.cs.utah.edu/formal_verification/ISP-release )
If you follow the instructions in our user manual and run into problems,
we will be most happy to help you.
Ganesh Gopalakrishnan
(*) well, you can even provide a "raw" file to ISP . ISP calls MPICH
from within, and arranges for a lot of the environment settings and
flags. So you can even see all the "file not found" messages and correct
them from within ISP. Once your code runs OK in ISP, then you can shift
the code to a larger cluster and do your performance tuning experiments.
That is, it may be easier to get rid of "file not found"s as well as
deadlocks from within ISP.
p.s. For those doing MPI code development for their research / classes,
we are very eager to work with you. We want to see how ISP fares,
whether it does not work as advertised, or if it surprised you by
finding a bug. Please drop us a note and we will work with you!
Our email is isp-dev at cs.utah.edu
