[mpich-discuss] Example MPICH2 multicore host file?
Scott Atchley atchley at myri.com
Thu Apr 2 19:41:02 CDT 2009
On Apr 2, 2009, at 8:10 PM, Steve Smith wrote:
> I am running mpich2 on two multicore machines (linux dual-quad-core
> and OSX dual-core).
Hopefully, the Mac is x86 and not PPC (endian issues).
> I haven't had any problems with building and running code. However,
> I've seen some behavior that makes me wonder if data/processing is
> actually being subdivided between my cores - or whether they are all
> getting the same data.
> I have not seen an example of a working MPICH2 hostfile. Based on
> the OPENMPI ans MPICH1 examples at http://cs.calvin.edu/curriculum/cs/374/homework/MPI/01/multicoreHostFiles.html
>  I'm thinking my MPICH2 hostfile should have a different format.
> Can anyone point me to a working example MPICH2 multicore hostfile?
The MPICH2 machinefile is the same as MPICH where you use:
<hostname>:<number of cores>
If you are using TCP and you have multiple interfaces, you can specify
which interface with:
<hostname>:<number of cores> ifhn=<hostname for preferred interface>
For example, if you have an eight core node with two networks and the
hostnames are foo-int and foo-ext (for internal and external
interface), you might want to use:
foo-ext:8 ifhn=foo-int
Scott
