[mpich-discuss] Executables from mpif90 can only be run with mpiexec
Jayesh Krishna jayesh at mcs.anl.gov
Tue Sep 30 14:46:50 CDT 2008
  This issue has been fixed in the 1.1.0a1 release (developer
pre-release). The fix will also be included in the upcoming 1.0.8 stable
release.
  Please try MPICH2 1.1.0a1 (available at
http://www.mcs.anl.gov/research/projects/mpich2/downloads/index.php?s=down
loads) or the latest source from trunk and get back to us if you still
have problems.
Jayesh
-----Original Message-----
[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Marcel Mohr
Sent: Tuesday, September 30, 2008 8:11 AM
Subject: [mpich-discuss] Executables from mpif90 can only be run with
mpiexec
Dear list
within the last mpich2 version I used (1.04) I could run executables
directly (serial) or with mpiexec (parallel). This is not possible anymore
with version 1.07 , running directly gives these errors
MPIDU_Socki_handle_connect(791): connection failure
(set=1,sock=16777216,errno=111:Connection refused) unable to connect
mpiexec tree, socket connection failed, error stack:
(set=1,sock=16777216,errno=111:Connection refused).
I was using for mpich2 compilation:
./configure --prefix=/usr/local/mpich2-intel' '--with-pm=smpd' 'CC=icc'
'CXX=icc'
'F90=ifort' '--enable-ROMIO' '--with-file-system=nfs' '--with-pmi=smpd'
'--with-device=ch3:ssm
Any hints/clues what is the reason for this behavior?
Cheers
Marcel
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080930/72c50ab7/attachment.htm>
