[mpich-discuss] Executables from mpif90 can only be run with mpiexec
    Marcel Mohr
    marcel at physik.tu-berlin.de
    Tue Sep 30 08:11:08 CDT 2008
Dear list
within the last mpich2 version I used (1.04) I could run executables
directly (serial) or with mpiexec (parallel). This is not possible
anymore with version 1.07 , running directly gives these errors
MPIDU_Socki_handle_connect(791): connection failure
(set=1,sock=16777216,errno=111:Connection refused)
unable to connect mpiexec tree, socket connection failed, error stack:
(set=1,sock=16777216,errno=111:Connection refused).
I was using for mpich2 compilation:
./configure --prefix=/usr/local/mpich2-intel' '--with-pm=smpd' 'CC=icc'
'CXX=icc'
'F90=ifort' '--enable-ROMIO' '--with-file-system=nfs' '--with-pmi=smpd'
'--with-device=ch3:ssm
Any hints/clues what is the reason for this behavior?
Cheers
Marcel
