[mpich-discuss] MPI x64 - buy advanced version
Jeff Squyres
jsquyres at cisco.com
Fri Sep 19 09:09:04 CDT 2008
On Sep 19, 2008, at 9:52 AM, Joao Paulo Lima Santos wrote:
> Really there's MPI_INTEGER8 to represents 8-bit integer, but not all
> variables can take this form, for example the COUNT:
I think you really mean "8 *byte*". :-)
> MPI_Send(void* buf,int count,MPI_Datatype datatype,
> int dest,int tag,MPI_Comm comm);
> I am sending a vector whose size exceeds representation 4-bit
> integer (COUNT). Internally, the MPI function does not appear to
> represent an entire 8-bit and returns an error message.
If you are sending a message that is larger than 2^31 elements, the
usual way to do this is to compose an MPI datatype that encompasses
multiple elements. Then you can have a "count" argument that is
smaller than 2^31.
Note, however, if you're programming in Fortran and you use a compiler
switch to automatically switch your default INTEGERs to be 8 bytes
long, this may cause problems if the MPI library was not also built
and compiled with the same compiler option.
Jeff Squyres
Cisco Systems
