[mpich-discuss] MPI x64 - buy advanced version
    ddkrause
    ddkrause at uni-bonn.de
    Fri Sep 19 09:27:56 CDT 2008
Hello,
Joao Paulo Lima Santos wrote:
> Dear THE SOURCE,
> Really there's MPI_INTEGER8 to represents 8-bit integer, but not all
> variables can take this form, for example the COUNT:
> MPI_Send(void* buf,int count,MPI_Datatype datatype,
>    int dest,int tag,MPI_Comm comm);
> I am sending a vector whose size exceeds representation 4-bit integer
> (COUNT). Internally, the MPI function does not appear to represent an
> entire 8-bit and returns an error message.
You are talking about 4 byte integers, don't you?
I think at least following the standard the count arguments needs to be
an integer. However the C standard does not specify the size of int.
Maybe you can use some compiler flag to increase the size of int?
Otherwise you probably need to split the message.
> Do you now some version that I can to do it?
> Sincerily yours.
> Joao Paulo
Best regards,
D. Krause
> Quoting The Source <thesourcehim at gmail.com>:
>> As far as I know, there's MPI_CHAR type that represents 8-bit integer
>> (no matter what platform). Works for me on Fedora 9 x86_64.
>> Joao Paulo Lima Santos ?????:
>>> Dear staff,
>>> I'm trying to run mpi in environment of 64bits (Win x64) and I've
>>> failled. I need to have integer variables which only can be
>>> represented by eigth bits. Is there a version of MPI that I can
>>> use?. Is it possible buy such version?
>>> Sincerily yours.
>>> Joao Paulo
