[mpich-discuss] Unable to connect issue
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Fri Sep 19 09:06:55 CDT 2008
# Can you run the MPI program on a single host ? (i.e., mpiexec -n 2
cpi.exe)
# Can you try specifying ipaddresses of the hosts instead of the hostnames
? (i.e., mpiexec -hosts 2 IPADDRESS_OF_IMAGES16 IPADDRESS_OF_IMAGES17
cpi.exe)
    If the above suggestions don't work please provide us the verbose
output of smpd and mpiexec. To get the verbose output of smpd & mpiexec,
# Stop any instances of smpd using, smpd -stop, command
# Run smpd in debug mode using, smpd -d, command
# Run mpiexec in the verbose mode using the "-verbose" option of mpiexec.
   Let us know the results.
(Note: In the command that you listed in your email both hostnames are the
same -- there is no images16 specified with "-hosts" arg of mpiexec. I am
assuming you meant "mpiexec -hosts 2 images16 images17 cpi.exe")
Jayesh
  _____
[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of bob ilgner
Sent: Friday, September 19, 2008 8:30 AM
Subject: Re: [mpich-discuss] Unable to connect issue
I am running XP Pro on the machines and am therefore using smpd. As far as
I know the mpd is used in the unix/linux environment. The smpd is
operational on both PCs. The local check for the status os the smpd on
either machine shows that they are running.  When i do a remote check with
smdp I get the same message.i.e.
smpd -status <remotehostname>
abort: unable to connect to <remotehostname>
Regards, bob
On Fri, Sep 19, 2008 at 1:38 PM, The Source <thesourcehim at gmail.com>
wrote:
do you have mpd ring running and connected on both machines?
bob ilgner пишет:
I have installed mpich2 1.0.7 on 2 XP Pro hosts and am trying to run the
cpi process on both hosts with the command
mpiexec -hosts 2 images17 images17 cpi
where images16 and images17 are the hosts and cpi is the supplied example
application and get the error:
abort: unable to connect to images16
I have checked passwords and regsitration is the same on both hosts.
Firewalls are both down. Host names defined in hosts file under system32.
I have ensured that smpd is operating on both machines. Usernames and
password are the same on both hosts and have both been delegated. I have
gone through the mpich2 user manual and find no way forward with this. Is
there anything else I could try ?
Would it help if I listed the output from the mpiexec with the verbose
switch on.
Regards, bob
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080919/9262cbfa/attachment.htm>
