[mpich-discuss] Unable to connect issue
    The Source
    thesourcehim at gmail.com
    Fri Sep 19 08:51:37 CDT 2008
Make sure smpd's listen on proper network addresses (not 127.0.0.1 or
something like that).
bob ilgner пишет:
> Hi,
> I am running XP Pro on the machines and am therefore using smpd. As
> far as I know the mpd is used in the unix/linux environment. The smpd
> is operational on both PCs. The local check for the status os the smpd
> on either machine shows that they are running.  When i do a remote
> check with smdp I get the same message.i.e.
> smpd -status <remotehostname>
> abort: unable to connect to <remotehostname>
> Regards, bob
> On Fri, Sep 19, 2008 at 1:38 PM, The Source <thesourcehim at gmail.com
> <mailto:thesourcehim at gmail.com>> wrote:
>     do you have mpd ring running and connected on both machines?
>     bob ilgner пишет:
>         I have installed mpich2 1.0.7 on 2 XP Pro hosts and am trying
>         to run the cpi process on both hosts with the command
>         mpiexec -hosts 2 images17 images17 cpi
>         where images16 and images17 are the hosts and cpi is the
>         supplied example application and get the error:
>         abort: unable to connect to images16
>         I have checked passwords and regsitration is the same on both
>         hosts. Firewalls are both down. Host names defined in hosts
>         file under system32. I have ensured that smpd is operating on
>         both machines. Usernames and password are the same on both
>         hosts and have both been delegated. I have gone through the
>         mpich2 user manual and find no way forward with this. Is there
>         anything else I could try ?
>         Would it help if I listed the output from the mpiexec with the
>         verbose switch on.
>         Regards, bob
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080919/02eefbd2/attachment.htm>
