[mpich-discuss] Unable to connect issue
bob ilgner bobilgner at gmail.com
Fri Sep 19 08:30:12 CDT 2008
I am running XP Pro on the machines and am therefore using smpd. As far as I
know the mpd is used in the unix/linux environment. The smpd is operational
on both PCs. The local check for the status os the smpd on either machine
shows that they are running.  When i do a remote check with smdp I get the
same message.i.e.
smpd -status <remotehostname>
abort: unable to connect to <remotehostname>
Regards, bob
On Fri, Sep 19, 2008 at 1:38 PM, The Source <thesourcehim at gmail.com> wrote:
> do you have mpd ring running and connected on both machines?
> bob ilgner пишет:
> I have installed mpich2 1.0.7 on 2 XP Pro hosts and am trying to run the
>> cpi process on both hosts with the command
>> mpiexec -hosts 2 images17 images17 cpi
>> where images16 and images17 are the hosts and cpi is the supplied example
>> application and get the error:
>> abort: unable to connect to images16
>> I have checked passwords and regsitration is the same on both hosts.
>> Firewalls are both down. Host names defined in hosts file under system32. I
>> have ensured that smpd is operating on both machines. Usernames and password
>> are the same on both hosts and have both been delegated. I have gone through
>> the mpich2 user manual and find no way forward with this. Is there anything
>> else I could try ?
>> Would it help if I listed the output from the mpiexec with the verbose
>> switch on.
>> Regards, bob
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080919/1737accb/attachment.htm>
