[mpich-discuss] unable to get mpich2 1.0.7 working
Kamaraju Kusumanchi kamaraju at gmail.com
Wed Sep 10 11:46:17 CDT 2008
I do not know what MPE logging is. So I probably don't need it!
But the inability to mpdboot a bunch of nodes remains still.
thanks
raju
On Wed, Sep 10, 2008 at 12:37 PM, Anthony Chan <chan at mcs.anl.gov> wrote:
> Your installcheck.log indicates that mpicc/mpif77 was able to
> compile and link program.  Also, the tests show that booting
> mpd locally on 1 machine (mpd &), you can run MPI program.
> But all MPE logging related tests fail (could be a write permission
> issue).  If you don't need to use MPE logging, you can ignore
> the issue for now.
> A.Chan
> ----- "Kamaraju Kusumanchi" <kamaraju at gmail.com> wrote:
>> [My reply below]
>> On Tue, Sep 9, 2008 at 11:54 PM, Anthony Chan <chan at mcs.anl.gov>
>> wrote:
>> > Did you launch mpd before doing "make testing" ?
>> > Something simpler before doing "make testing":
>> > "mpd &" and then do "make installcheck" which will
>> > check if mpi compiler wrappers are working.
>> > A.Chan
>> I tried the simpler method you suggested.
>> $mpd &
>> [1] 20775
>> $make installcheck 2>&1 | tee installcheck.log
>> I attached the installcheck.log as an attachment.
>> Rajeev suggested that my mpd might have died down accidentally. I was
>> also not sure whether I did "mpd&" before running the make testing.
>> The installation guide does mention to run "mpd&" before running
>> "make
>> testing". Do you want me to try that as well?
>> thanks
>> raju
