[mpich-discuss] unable to get mpich2 1.0.7 working
    Anthony Chan
    chan at mcs.anl.gov
    Wed Sep 10 11:37:11 CDT 2008
Your installcheck.log indicates that mpicc/mpif77 was able to
compile and link program.  Also, the tests show that booting
mpd locally on 1 machine (mpd &), you can run MPI program.
But all MPE logging related tests fail (could be a write permission
issue).  If you don't need to use MPE logging, you can ignore
the issue for now.
A.Chan
----- "Kamaraju Kusumanchi" <kamaraju at gmail.com> wrote:
> [My reply below]
> On Tue, Sep 9, 2008 at 11:54 PM, Anthony Chan <chan at mcs.anl.gov>
> wrote:
> > Did you launch mpd before doing "make testing" ?
> > Something simpler before doing "make testing":
> > "mpd &" and then do "make installcheck" which will
> > check if mpi compiler wrappers are working.
> > A.Chan
> I tried the simpler method you suggested.
> $mpd &
> [1] 20775
> $make installcheck 2>&1 | tee installcheck.log
> I attached the installcheck.log as an attachment.
> Rajeev suggested that my mpd might have died down accidentally. I was
> also not sure whether I did "mpd&" before running the make testing.
> The installation guide does mention to run "mpd&" before running
> "make
> testing". Do you want me to try that as well?
> thanks
> raju
