[mpich-discuss] Memory issue of MPICH2 when displaying a real array
Gib Bogle
g.bogle at auckland.ac.nz
Tue Oct 14 15:51:20 CDT 2008
What happens to the memory usage if the loop is executed a large but
finite number of times? e.g.
do k = 1,100
call mpi_display_real_array(myid, a)
enddo
Quoting Yaqi Wang <yaqiwang at gmail.com>:
> Yes, that is an infinite loop. But users can terminate the program at any
> time with Control+C provided by the OS.
> I just want to show the memory cost keeps increasing if the program is not
> stopped. Sorry for the confusing.
> Thanks,
> yaqi
> On Tue, Oct 14, 2008 at 11:12 AM, Jayesh Krishna <jayesh at mcs.anl.gov> wrote:
>> Hi,
>> I am not a Fortran expert but what is the exit condition for the while
>> loop ?
>> do while (.true.)
>> enddo
>> Looks like an infinite loop to me.
>> Regards,
>> Jayesh
>> *From:* owner-mpich-discuss at mcs.anl.gov [mailto:
>> owner-mpich-discuss at mcs.anl.gov] *On Behalf Of *Yaqi Wang
>> *Sent:* Friday, October 10, 2008 8:28 PM
>> *To:* mpich-discuss at mcs.anl.gov
>> *Subject:* [mpich-discuss] Memory issue of MPICH2 when displaying a real
>> array
>> I am using MPICH2 1.0.7 with Windows XP SP3. The compiler is Intel
>> Visual Fortran 10.1.
>> I compiled the following code.
>> program aaa
>> use MPI
>> implicit none
>> integer :: ierr, myid, numprocs
>> integer :: i
>> real(8) :: a(10)
>> ! initialization of MPI
>> CALL MPI_INIT( ierr )
>> CALL MPI_COMM_RANK( MPI_COMM_WORLD, myid, ierr )
>> CALL MPI_COMM_SIZE( MPI_COMM_WORLD, numprocs, ierr )
>> a = 0.0_8
>> do while (.true.)
>> enddo
>> CALL MPI_FINALIZE(ierr)
>> contains
>> SUBROUTINE mpi_display_real_array(myid, num)
>> integer myid
>> REAL(8) :: num(:)
>> WRITE(*,*) myid, num
>> RETURN
>> END SUBROUTINE mpi_display_real_array
>> end program aaa
>> And be able to run it with 'mpiexec -n 1 test.exe' on my local
>> computer. test.f90 is the name of the source code. Number of
>> processors here is irrelavant, I used 1.
>> I noticed after running it, the memory cost of the 'smpd' process
>> kept increasing, which I did not expect. Anybody knows what I did
>> wrong here?
>> Thanks.
This message was sent using IMP, the Internet Messaging Program.
