[mpich-discuss] Memory issue of MPICH2 when displaying a real array
Jayesh Krishna
jayesh at mcs.anl.gov
Tue Oct 14 15:14:12 CDT 2008
Are you running out of memory ? Do you run out of memory when you comment
out WRITE statements (The process manager might have to buffer some of the
stdout before redirecting it to proc with rank=0) ?
Jayesh
_____
Sent: Tuesday, October 14, 2008 2:55 PM
To: Jayesh Krishna
Cc: mpich-discuss at mcs.anl.gov
Subject: Re: [mpich-discuss] Memory issue of MPICH2 when displaying a real
array
Yes, that is an infinite loop. But users can terminate the program at any
time with Control+C provided by the OS.
I just want to show the memory cost keeps increasing if the program is not
stopped. Sorry for the confusing.
yaqi
On Tue, Oct 14, 2008 at 11:12 AM, Jayesh Krishna <jayesh at mcs.anl.gov>
wrote:
I am not a Fortran expert but what is the exit condition for the while
loop ?
do while (.true.)
call mpi_display_real_array(myid, a)
enddo
Looks like an infinite loop to me.
Jayesh
_____
[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Yaqi Wang
Sent: Friday, October 10, 2008 8:28 PM
Subject: [mpich-discuss] Memory issue of MPICH2 when displaying a real
array
I am using MPICH2 1.0.7 with Windows XP SP3. The compiler is Intel
Visual Fortran 10.1.
I compiled the following code.
program aaa
use MPI
implicit none
integer :: ierr, myid, numprocs
integer :: i
real(8) :: a(10)
! initialization of MPI
CALL MPI_INIT( ierr )
CALL MPI_COMM_RANK( MPI_COMM_WORLD, myid, ierr )
CALL MPI_COMM_SIZE( MPI_COMM_WORLD, numprocs, ierr )
a = 0.0_8
do while (.true.)
enddo
CALL MPI_FINALIZE(ierr)
contains
SUBROUTINE mpi_display_real_array(myid, num)
integer myid
REAL(8) :: num(:)
WRITE(*,*) myid, num
RETURN
END SUBROUTINE mpi_display_real_array
end program aaa
And be able to run it with 'mpiexec -n 1 test.exe' on my local
computer. test.f90 is the name of the source code. Number of
processors here is irrelavant, I used 1.
I noticed after running it, the memory cost of the 'smpd' process
kept increasing, which I did not expect. Anybody knows what I did
wrong here?
Thanks.
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20081014/8aee40cb/attachment.htm>
