[mpich-discuss] Installation problem mpich2-1.0.6/1.0.7 on LINUX MANDRIVA 2008.1
    Rajeev Thakur
    thakur at mcs.anl.gov
    Thu Oct  9 13:12:15 CDT 2008
If the 6 failing tests are the "i" versions of I/O tests, you can ignore
them for now.
Rajeev
> -----Original Message-----
> From: owner-mpich-discuss at mcs.anl.gov
> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of
> Broeders, Cornelis
> Sent: Thursday, October 09, 2008 5:51 AM
> To: mpich-discuss at mcs.anl.gov
> Subject: AW: [mpich-discuss] Installation problem
> After your reply I did some more detailed investigations:
> - using "./configure --prefix=/home/opt/mpich2-1.0.7 CC=gcc
> F77=g95 F90=g95", "make testing" ended with "All 497 tests passed!"
> - adding "--enable-g=all --enable-error-messages=all", result
> was that 6 tests failed. These options were my initial ones
> of my inquiry.
> - adding only "--enable-g=all", result is "6 tests failed out of 497"
> My next step now will be to further analyze my mcnpx problem.
> I had introduced the "--enable-g=all" option to obtain
> traceback information for this problem.
> Another question is related to the the output file
> "summary.xml" of "make testing". I do not succeeed to produce
> a good readable representation. I tried to open the file with
> firefox in a subdirectoty, together with the provided file
> "TestResults.xsl", but this fails with "XML Parsing Error: no
> element found". The postion is after last line in file summary.xml.
> Thank you very much for your support,
> C. Broeders
> -----Ursprüngliche Nachricht-----
> Von: owner-mpich-discuss at mcs.anl.gov
> [mailto:owner-mpich-discuss at mcs.anl.gov] Im Auftrag von Rajeev Thakur
> Gesendet: Mittwoch, 8. Oktober 2008 23:39
> An: mpich-discuss at mcs.anl.gov
> Betreff: RE: [mpich-discuss] Installation problem
> What were the exact parameters you passed to configure, and
> what was the output printed on the screen when you ran "make
> testing". If the "i" versions of the I/O tests are giving
> trouble, you can try configuring with --disable-aio.
> Rajeev
> > Broeders, Cornelis
> > Sent: Wednesday, October 08, 2008 3:34 PM
> > Subject: [mpich-discuss] Installation problem
> > Dear all,
> > during implementation of mcnpx2.6.f on LINUX MANDRIVA 2008.1
> > I encountered problems in case of parallel computing with
> > mpich2-1.0.6/7 when using 3 processes for 2 processors on one
> > notebook ACER Travelmate 6592G. The same executable runs fine
> > with 2 processes, using one processor. Similar errors
> > occurred for different compiler options: icc/ifort intel
> > 10.1/9.1. Earlier installations with LINUX SuSE9.3 worked
> > fine for such cases.
> > After some trouble-shooting, I decided to look into detail in
> > the testing of mpich2. I observed that all test combinations
> > ended with errors after "make testing". My last detailed
> > check was performed with gcc4.2/g95 0.91. I applied the "-i4"
> > option in g95. The "make testing" command produces a huge
> > "summary.xml" file, mainly containing lines of type "nest
> > stack exceeded at mpir_request.c:174". Further analysis
> > showed that these messages are produced in test programs
> > "iwrite.." in directories "io" for all compilers(f77, f90, cxx).
> > I am not sure about correlation between my mcnpx and
> > "iwrir.." problem, but I have to go step by step.
> > Could somebody comment and/or give hints for next steps to
> > get mcnpx running with 2 processors on one system with recent
> > LINUX version??
> > Thank you very much in advance for any comment.
> > Best regards,
> > C. Broeders     http://www.cornelis-broeders.de
