AW: [mpich-discuss] Installation problem mpich2-1.0.6/1.0.7 on LINUX MANDRIVA 2008.1
    Broeders, Cornelis
    cornelis.broeders at irs.fzk.de
    Thu Oct  9 05:51:12 CDT 2008
After your reply I did some more detailed investigations:
- using "./configure --prefix=/home/opt/mpich2-1.0.7 CC=gcc F77=g95 F90=g95", "make testing" ended with "All 497 tests passed!"
- adding "--enable-g=all --enable-error-messages=all", result was that 6 tests failed. These options were my initial ones of my inquiry.
- adding only "--enable-g=all", result is "6 tests failed out of 497"
My next step now will be to further analyze my mcnpx problem. I had introduced the "--enable-g=all" option to obtain traceback information for this problem.
Another question is related to the the output file "summary.xml" of "make testing". I do not succeeed to produce a good readable representation. I tried to open the file with firefox in a subdirectoty, together with the provided file "TestResults.xsl", but this fails with "XML Parsing Error: no element found". The postion is after last line in file summary.xml.
Thank you very much for your support,
C. Broeders
-----Ursprüngliche Nachricht-----
Von: owner-mpich-discuss at mcs.anl.gov [mailto:owner-mpich-discuss at mcs.anl.gov] Im Auftrag von Rajeev Thakur
Gesendet: Mittwoch, 8. Oktober 2008 23:39
An: mpich-discuss at mcs.anl.gov
Betreff: RE: [mpich-discuss] Installation problem mpich2-1.0.6/1.0.7 on LINUX MANDRIVA 2008.1
What were the exact parameters you passed to configure, and what was the output printed on the screen when you ran "make testing". If the "i" versions of the I/O tests are giving trouble, you can try configuring with --disable-aio.
Rajeev
> -----Original Message-----
> From: owner-mpich-discuss at mcs.anl.gov
> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of
> Broeders, Cornelis
> Sent: Wednesday, October 08, 2008 3:34 PM
> To: mpich-discuss at mcs.anl.gov
> Subject: [mpich-discuss] Installation problem
> Dear all,
> during implementation of mcnpx2.6.f on LINUX MANDRIVA 2008.1
> I encountered problems in case of parallel computing with
> mpich2-1.0.6/7 when using 3 processes for 2 processors on one
> notebook ACER Travelmate 6592G. The same executable runs fine
> with 2 processes, using one processor. Similar errors
> occurred for different compiler options: icc/ifort intel
> 10.1/9.1. Earlier installations with LINUX SuSE9.3 worked
> fine for such cases.
> After some trouble-shooting, I decided to look into detail in
> the testing of mpich2. I observed that all test combinations
> ended with errors after "make testing". My last detailed
> check was performed with gcc4.2/g95 0.91. I applied the "-i4"
> option in g95. The "make testing" command produces a huge
> "summary.xml" file, mainly containing lines of type "nest
> stack exceeded at mpir_request.c:174". Further analysis
> showed that these messages are produced in test programs
> "iwrite.." in directories "io" for all compilers(f77, f90, cxx).
> I am not sure about correlation between my mcnpx and
> "iwrir.." problem, but I have to go step by step.
> Could somebody comment and/or give hints for next steps to
> get mcnpx running with 2 processors on one system with recent
> LINUX version??
> Thank you very much in advance for any comment.
> Best regards,
> C. Broeders     http://www.cornelis-broeders.de
