[mpich-discuss] Installation problem mpich2-1.0.6/1.0.7 on LINUX MANDRIVA 2008.1
    Rajeev Thakur
    thakur at mcs.anl.gov
    Wed Oct  8 16:38:56 CDT 2008
What were the exact parameters you passed to configure, and what was the
output printed on the screen when you ran "make testing". If the "i"
versions of the I/O tests are giving trouble, you can try configuring with
--disable-aio.
Rajeev
> -----Original Message-----
> From: owner-mpich-discuss at mcs.anl.gov
> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of
> Broeders, Cornelis
> Sent: Wednesday, October 08, 2008 3:34 PM
> To: mpich-discuss at mcs.anl.gov
> Subject: [mpich-discuss] Installation problem
> Dear all,
> during implementation of mcnpx2.6.f on LINUX MANDRIVA 2008.1
> I encountered problems in case of parallel computing with
> mpich2-1.0.6/7 when using 3 processes for 2 processors on one
> notebook ACER Travelmate 6592G. The same executable runs fine
> with 2 processes, using one processor. Similar errors
> occurred for different compiler options: icc/ifort intel
> 10.1/9.1. Earlier installations with LINUX SuSE9.3 worked
> fine for such cases.
> After some trouble-shooting, I decided to look into detail in
> the testing of mpich2. I observed that all test combinations
> ended with errors after "make testing". My last detailed
> check was performed with gcc4.2/g95 0.91. I applied the "-i4"
> option in g95. The "make testing" command produces a huge
> "summary.xml" file, mainly containing lines of type "nest
> stack exceeded at mpir_request.c:174". Further analysis
> showed that these messages are produced in test programs
> "iwrite.." in directories "io" for all compilers(f77, f90, cxx).
> I am not sure about correlation between my mcnpx and
> "iwrir.." problem, but I have to go step by step.
> Could somebody comment and/or give hints for next steps to
> get mcnpx running with 2 processors on one system with recent
> LINUX version??
> Thank you very much in advance for any comment.
> Best regards,
> C. Broeders     http://www.cornelis-broeders.de
