[mpich-discuss] forrtl errors
Rajeev Thakur thakur at mcs.anl.gov
Tue Oct 7 14:09:47 CDT 2008
Doesn't look like an MPI problem. "No such file or directory" means the
application has file name/path in it that is not found on your system.
Rajeev
> -----Original Message-----
> From: owner-mpich-discuss at mcs.anl.gov
> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of
> Christopher Tanner
> Sent: Tuesday, October 07, 2008 1:18 PM
> To: mpich-discuss at mcs.anl.gov
> Subject: [mpich-discuss] forrtl errors
> Hi All -
> I am receiving the same errors in multiple applications when
> I try to
> run them over MPICH2. They all read:
> forrtl: Input/output error
> forrtl: No such file or directory
> forrtl: severe ...
> This doesn't happen when I try to run any tests (i.e. mpiexec ...
> hostname), only whenever I run the applications. Additionally, it
> happens with pre-compiled (i.e. commercial applications)
> applications
> as well as applications compiled on the machine (i.e. open-source
> applications). At first I thought it was something to do with the
> application, now I'm starting to think I've done something
> wrong with
> MPICH2. Below is the configure command I used:
> ./configure --prefix=/usr/local/mpi/mpich2 --enable-f77
> --enable-f90 --
> enable-cxx --enable-sharedlibs=gcc --enable-fast=defopt
> CC=icc CFLAGS=-
> m64 CXX=icpc CXXFLAGS=-m64 F77=ifort FFLAGS=-m64 F90=ifort
> F90FLAGS=-m64
> Anyone have any clues? Thanks!
> Chris Tanner
> Space Systems Design Lab
> Georgia Institute of Technology
> christopher.tanner at gatech.edu
