[mpich-discuss] MPICH2 APP on windows
Addepalli, Srirangam V
srirangam.v.addepalli at ttu.edu
Wed Nov 12 10:28:30 CST 2008
Thank you. It worked to a extent as in when I run the command with the suggestions I am able to get past read input file stage.
NOT Working:
C:\Program Files (x86)\MPICH2\bin>mpiexec.exe -np 8 -host compute-3 -map H:\\JAN
US\D H:\BIN\nwchem.exe H:\BIN\siosi3.nw
argument 1 = H:\BIN\siosi3.nw
could not open a file in permanent directory: H:/BIN/
could not open a file in scratch directory: H:/BIN/
Both permanent and scratch directory not accessible
Working:
C:\Program Files (x86)\MPICH2\bin>mpiexec.exe -np 8 -host compute-1 -map H:\\JAN
I think I have some permissions messed up. Suggestions ?
Rangam
From: Jayesh Krishna [mailto:jayesh at mcs.anl.gov]
Sent: Wednesday, November 12, 2008 6:22 AM
To: Addepalli, Srirangam V
Cc: mpich-discuss at mcs.anl.gov
Subject: RE: [mpich-discuss] MPICH2 APP on windows
If you are sharing your input file across different machines using a network share you must use the "-map" option of mpiexec to map the network share for your job (Please refer the window's developer's guide for more details on the mpiexec options - available at http://www.mcs.anl.gov/research/projects/mpich2/documentation/index.php?s=docs).
Also try specifying the complete path for the input file (eg: c:\testpgm\siosi3.nw).
Let us know the results.
Jayesh
From: mpich-discuss-bounces at mcs.anl.gov [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Addepalli, Srirangam V
Sent: Tuesday, November 11, 2008 4:04 PM
Subject: [mpich-discuss] MPICH2 APP on windows
Hello All.
I am trying to run a windows nwchem executable compile in cygwin using MPICH2 libraries on a windows cluster. The strange this with this executable is it runs on only the system that it has been compiler on. When I try to run the executable using the command or the interface , nwchem executable fails to find the input file.
Not Working:
C:\Program Files (x86)\MPICH2\bin>mpiexec.exe -np 8 -host compute-3 nwchem.exe
siosi3.nw
argument 1 = siosi3.nw
Unable to open siosi3.nw --- appending .nw
Working
C:\Program Files (x86)\MPICH2\bin>mpiexec.exe -np 8 -host compute-1 nwchem.exe
siosi3.nw
Running a job on compute-1 works fine. ( I've compiled this application here).
Command on Compute-3 submits a job to compute-1 works.
Command on Compute-3 submits a job to run on Compute-3 does not work (not able to read input file)
Command on Compute-1 to Compute-1 works.
Command on Compute-1 to Compute-3 Does not work (not able to read input file)
I think this has to do with my setup. Where should I be looking for to debug this strange issue.
Rangam
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20081112/f1634a11/attachment.htm>
