[mpich-discuss] MPICH2 APP on windows
Jayesh Krishna
jayesh at mcs.anl.gov
Wed Nov 12 10:46:36 CST 2008
You can try to manually map the network share (using the same
username/password that you used/registered for the MPI job) from machine
compute-3 and see if you can access the files.
Jayesh
_____
From: Addepalli, Srirangam V [mailto:srirangam.v.addepalli at ttu.edu]
Sent: Wednesday, November 12, 2008 10:29 AM
To: Jayesh Krishna
Cc: mpich-discuss at mcs.anl.gov
Subject: RE: [mpich-discuss] MPICH2 APP on windows
Thank you. It worked to a extent as in when I run the command with the
suggestions I am able to get past read input file stage.
NOT Working:
C:\Program Files (x86)\MPICH2\bin>mpiexec.exe -np 8 -host compute-3 -map
H:\\JAN
US\D H:\BIN\nwchem.exe H:\BIN\siosi3.nw
argument 1 = H:\BIN\siosi3.nw
could not open a file in permanent directory: H:/BIN/
could not open a file in scratch directory: H:/BIN/
Both permanent and scratch directory not accessible
Working:
C:\Program Files (x86)\MPICH2\bin>mpiexec.exe -np 8 -host compute-1 -map
H:\\JAN
I think I have some permissions messed up. Suggestions ?
Rangam
From: Jayesh Krishna [mailto:jayesh at mcs.anl.gov]
Sent: Wednesday, November 12, 2008 6:22 AM
To: Addepalli, Srirangam V
If you are sharing your input file across different machines using a
network share you must use the "-map" option of mpiexec to map the network
share for your job (Please refer the window's developer's guide for more
details on the mpiexec options - available at
http://www.mcs.anl.gov/research/projects/mpich2/documentation/index.php?s=
docs).
Also try specifying the complete path for the input file (eg:
c:\testpgm\siosi3.nw).
Let us know the results.
Jayesh
_____
[mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Addepalli,
Srirangam V
Sent: Tuesday, November 11, 2008 4:04 PM
Subject: [mpich-discuss] MPICH2 APP on windows
Hello All.
I am trying to run a windows nwchem executable compile in cygwin using
MPICH2 libraries on a windows cluster. The strange this with this
executable is it runs on only the system that it has been compiler on.
When I try to run the executable using the command or the interface ,
nwchem executable fails to find the input file.
Not Working:
nwchem.exe
siosi3.nw
argument 1 = siosi3.nw
Unable to open siosi3.nw --- appending .nw
Working
nwchem.exe
siosi3.nw
Running a job on compute-1 works fine. ( I've compiled this application
here).
Command on Compute-3 submits a job to compute-1 works.
Command on Compute-3 submits a job to run on Compute-3 does not work (not
able to read input file)
Command on Compute-1 to Compute-1 works.
Command on Compute-1 to Compute-3 Does not work (not able to read input
file)
I think this has to do with my setup. Where should I be looking for to
debug this strange issue.
Rangam
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20081112/2003ccc3/attachment.htm>
