[mpich-discuss] MPICH2 APP on windows
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Wed Nov 12 06:22:05 CST 2008
 If you are sharing your input file across different machines using a
network share you must use the "-map" option of mpiexec to map the network
share for your job (Please refer the window's developer's guide for more
details on the mpiexec options - available at
http://www.mcs.anl.gov/research/projects/mpich2/documentation/index.php?s=
docs).
 Also try specifying the complete path for the input file (eg:
c:\testpgm\siosi3.nw).
 Let us know the results.
Jayesh
  _____
[mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Addepalli,
Srirangam V
Sent: Tuesday, November 11, 2008 4:04 PM
Subject: [mpich-discuss] MPICH2 APP on windows
Hello All.
I  am trying to run a windows nwchem executable compile in cygwin using
MPICH2 libraries on a  windows cluster.  The strange this with this
executable is it runs on only the system that it has been compiler on.
When I try to run the executable using the command or the interface ,
nwchem executable fails to find the input file.
Not Working:
C:\Program Files (x86)\MPICH2\bin>mpiexec.exe -np 8 -host  compute-3
nwchem.exe
siosi3.nw
 argument  1 = siosi3.nw
  Unable to open siosi3.nw --- appending .nw
  could not open a file in permanent directory:
Working
C:\Program Files (x86)\MPICH2\bin>mpiexec.exe -np 8 -host  compute-1
nwchem.exe
siosi3.nw
Running a job on compute-1 works fine. ( I've compiled this application
here).
Command on Compute-3  submits a job to compute-1 works.
Command on Compute-3 submits a job to run on Compute-3 does not work  (not
able to read input file)
Command on  Compute-1 to Compute-1 works.
Command on  Compute-1 to Compute-3  Does not work (not able to read input
file)
I think this has to do with my setup. Where should I be looking for to
debug this strange issue.
Rangam
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20081112/4765480d/attachment.htm>
