[mpich-discuss] MPICH2 APP on windows
    Addepalli, Srirangam V
    srirangam.v.addepalli at ttu.edu
    Tue Nov 11 16:04:03 CST 2008
Hello All.
I  am trying to run a windows nwchem executable compile in cygwin using MPICH2 libraries on a  windows cluster.  The strange this with this executable is it runs on only the system that it has been compiler on. When I try to run the executable using the command or the interface , nwchem executable fails to find the input file.
Not Working:
C:\Program Files (x86)\MPICH2\bin>mpiexec.exe -np 8 -host  compute-3 nwchem.exe
siosi3.nw
 argument  1 = siosi3.nw
  Unable to open siosi3.nw --- appending .nw
  could not open a file in permanent directory:
Working
C:\Program Files (x86)\MPICH2\bin>mpiexec.exe -np 8 -host  compute-1  nwchem.exe
siosi3.nw
Running a job on compute-1 works fine. ( I've compiled this application here).
Command on Compute-3  submits a job to compute-1 works.
Command on Compute-3 submits a job to run on Compute-3 does not work  (not able to read input file)
Command on  Compute-1 to Compute-1 works.
Command on  Compute-1 to Compute-3  Does not work (not able to read input file)
I think this has to do with my setup. Where should I be looking for to debug this strange issue.
Rangam
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20081111/04507bc6/attachment.htm>
