[mpich-discuss] mpiexec and working directory
Reuti reuti at Staff.Uni-Marburg.DE
Sat Nov 8 05:39:56 CST 2008
Am 07.11.2008 um 20:35 schrieb Tiago Silva:
> Problem solved. I remembered that there was also an mpd version of
> mpich2 on the same machine and it works as expected:
> [tsilva at admin1 examples]$ mpd &
> [1] 12297
> [tsilva at admin1 examples]$ /n1ge6/mpich2-1.0.3/bin/mpiexec -n 2 pwd
> /n1ge6/mpich2-1.0.3/examples
> I wasn't using it because I couldn't  integrate it with SGE, unlike
> the smpd running with -nopm. But that is another story.
I will update the Howto at http://gridengine.sunsource.net/howto/
mpich2-integration/mpich2-integration.html in the next days to also
include a Tight Integration for the MPD method for startup.
-- Reuti
> Thanks for the help,
> Tiago
> Jayesh Krishna wrote:
>>  Hi,
>>   When you install MPICH2 make sure that you install the latest
>> stable version, 1.0.8. You could also ask your sysadmin to install
>> MPICH2+smpd in another directory  so that you can test MPICH2+smpd
>> (1.0.8).
>> Regards,
>> Jayesh
>> -----Original Message-----
>> From: mpich-discuss-bounces at mcs.anl.gov [mailto:mpich-discuss-
>> bounces at mcs.anl.gov] On Behalf Of Tiago Silva
>> Sent: Friday, November 07, 2008 12:26 PM
>> To: mpich-discuss at mcs.anl.gov
>> Subject: Re: [mpich-discuss] mpiexec and working directory
>> So could that explain this behavior? I need to justify asking a
>> very busy sysadmin to get the daemons  on a 25 node cluster.
>> Tiago
>> Rajeev Thakur wrote:
>> > Oh, you are using SMPD. Can you try with the default MPD process
>> manager?
>> > You have to build MPICH2 again for that.
>> > Rajeev
>> >> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Tiago
>> Silva
>> >> Sent: Friday, November 07, 2008 12:18 PM
>> >> Thanks Rajeev, this shows the problem nicely:
>> >> [tsilva at admin1 work]$ /n1ge6/mpich2/smpd/bin/mpiexec -nopm -ssh
>> -l -n
>> >> 2 pwd /raid1/tsilva /raid1/tsilva
>> >> [tsilva at admin1 work]$ /n1ge6/mpich2/smpd/bin/mpiexec -nopm -ssh -l
>> >> -wdir /tmp/ -n 2 pwd /raid1/tsilva /raid1/tsilva
>> >> [tsilva at admin1 work]$ ls runjob.err
>> >> runjob.err
>> >> -wdir /tmp/ -n 2 ls -l runjob.err
>> >> ls: runjob.err: No such file or directory
>> >> Could this have anything to do with running mpiexec deamonless
>> >> (although mpich was compiled with smpd)?
>> >> I noticed the same behavior with my regular setup of also
>> deamonless
>> >> mpirun and mpich1. Only after calling mpi_init in the code did the
>> >> working dir change from being $home to the local dir.
>> >> Cheers,
>> >> Tiago
>> >>    >>> Can you try these simple commands:
>> >>> mpiexec -l -n 2 pwd   >>>   ## shows if you execute in the dir
>> you think you are in
>> >>> mpiexec -l -wdir /tmp -n 2 pwd   >>>   ## similar to above but
>> shows you moved to /tmp
>> >>> mpiexec -l -n 2 ls -l some_filename   >>>   ## shows if some
>> expected file really is in the working dir
>> >>>> tsilva at coas.oregonstate.edu
>> >>>> Sent: Friday, November 07, 2008 1:26 AM
>> >>>> Quoting Rajeev Thakur <thakur at mcs.anl.gov>:
>> >>>>    >>>>        >>>>> If you cd to the directory containing
>> the executable, say
>> >>>>>      >>>>>          >>>> a.out, and
>> >>>>    >>>>        >>>>> do "mpiexec -n 2 a.out" does it expect
>> to find input
>> >>>>>          >> files in your
>> >>    >>>>> home directory? That's odd.
>> >>>>>      >>>>>          >>>> That is correct. I have tried
>> another simpler code and the same
>> >>>> thing happens.
>> >>>>>>            >> Tiago Silva
>> >>    >>>>>> Sent: Thursday, November 06, 2008 6:02 PM
>> >>>>>>        >>>>>>            >>>>>>> 1.0.3 is an ancient
>> version of MPICH2. Try the latest
>> >>>>>>>          >>>>>>>              >>>>>> version, 1.0.8.
>> >>>>>>        >>>>>> I will ask my systems administrator to do so.
>> >>>>>>        >>>>>>            >>>>>>> The parameters to mpiexec
>> are not identical between MPICH-1 and
>> >>>>>>> MPICH2. Do mpiexec --help. Make sure you are calling
>> >>>>>>>          >>>>>>>              >>>>>> MPICH2's mpiexec, not
>> MPICH-1's.
>> >>>>>>        >>>>>> I am actually invoking mpiexec with its full
>> path. Is there any
>> >>>>>> incorrect parameter on my mpiexec call?
>> >>>>>> I
>> >>>>>>        >>>>>>            >>>>>>> If your input files are in
>> the same directory as the
>> >>>>>>>          >>>>>>>              >>>>>> executable, you
>> >>>>>>        >>>>>>            >>>>>>> should not need to specify
>> anything.
>> >>>>>>>          >>>>>>>              >>>>>> But that is exactly
>> the problem. The executable can't find
>> >>>>>>        >>>>>>            >>>> the input
>> >>>>    >>>>        >>>>>> files on the working directory.
