[mpich-discuss] mpiexec and working directory
    Tiago Silva
    tsilva at coas.oregonstate.edu
    Fri Nov  7 13:35:29 CST 2008
Problem solved. I remembered that there was also an mpd version of
mpich2 on the same machine and it works as expected:
[tsilva at admin1 examples]$ mpd &
[1] 12297
[tsilva at admin1 examples]$ /n1ge6/mpich2-1.0.3/bin/mpiexec -n 2 pwd
/n1ge6/mpich2-1.0.3/examples
I wasn't using it because I couldn't  integrate it with SGE, unlike the
smpd running with -nopm. But that is another story.
Thanks for the help,
Tiago
Jayesh Krishna wrote:
>  Hi,
>   When you install MPICH2 make sure that you install the latest stable
> version, 1.0.8. You could also ask your sysadmin to install
> MPICH2+smpd in another directory  so that you can test MPICH2+smpd
> (1.0.8).
> Regards,
> Jayesh
> -----Original Message-----
> From: mpich-discuss-bounces at mcs.anl.gov
> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Tiago Silva
> Sent: Friday, November 07, 2008 12:26 PM
> To: mpich-discuss at mcs.anl.gov
> Subject: Re: [mpich-discuss] mpiexec and working directory
> So could that explain this behavior? I need to justify asking a very
> busy sysadmin to get the daemons  on a 25 node cluster.
> Tiago
> Rajeev Thakur wrote:
> > Oh, you are using SMPD. Can you try with the default MPD process
> manager?
> > You have to build MPICH2 again for that.
> > Rajeev
> >> Sent: Friday, November 07, 2008 12:18 PM
> >> Thanks Rajeev, this shows the problem nicely:
> >> [tsilva at admin1 work]$ /n1ge6/mpich2/smpd/bin/mpiexec -nopm -ssh -l -n
> >> 2 pwd /raid1/tsilva /raid1/tsilva
> >> -wdir /tmp/ -n 2 pwd /raid1/tsilva /raid1/tsilva
> >> [tsilva at admin1 work]$ ls runjob.err
> >> runjob.err
> >> -wdir /tmp/ -n 2 ls -l runjob.err
> >> ls: runjob.err: No such file or directory
> >> Could this have anything to do with running mpiexec deamonless
> >> (although mpich was compiled with smpd)?
> >> I noticed the same behavior with my regular setup of also deamonless
> >> mpirun and mpich1. Only after calling mpi_init in the code did the
> >> working dir change from being $home to the local dir.
> >> Cheers,
> >> Tiago
> >>> Can you try these simple commands:
> >>> mpiexec -l -n 2 pwd
> >>>   ## shows if you execute in the dir you think you are in
> >>> mpiexec -l -wdir /tmp -n 2 pwd
> >>>   ## similar to above but shows you moved to /tmp
> >>> mpiexec -l -n 2 ls -l some_filename
> >>>   ## shows if some expected file really is in the working dir
> >>>> Sent: Friday, November 07, 2008 1:26 AM
> >>>> Quoting Rajeev Thakur <thakur at mcs.anl.gov>:
> >>>>> If you cd to the directory containing the executable, say
> >>>> a.out, and
> >>>>> do "mpiexec -n 2 a.out" does it expect to find input
> >> files in your
> >>>>> home directory? That's odd.
> >>>> That is correct. I have tried another simpler code and the same
> >>>> thing happens.
> >> Tiago Silva
> >>>>>> Sent: Thursday, November 06, 2008 6:02 PM
> >>>>>>> 1.0.3 is an ancient version of MPICH2. Try the latest
> >>>>>> version, 1.0.8.
> >>>>>> I will ask my systems administrator to do so.
> >>>>>>> The parameters to mpiexec are not identical between MPICH-1 and
> >>>>>>> MPICH2. Do mpiexec --help. Make sure you are calling
> >>>>>> MPICH2's mpiexec, not MPICH-1's.
> >>>>>> I am actually invoking mpiexec with its full path. Is there any
> >>>>>> incorrect parameter on my mpiexec call?
> >>>>>> I
> >>>>>>> If your input files are in the same directory as the
> >>>>>> executable, you
> >>>>>>> should not need to specify anything.
> >>>>>> But that is exactly the problem. The executable can't find
> >>>> the input
> >>>>>> files on the working directory.
