[mpich-discuss] MPI_File_set_view Error:  ADIOI_Count_contiguous_blocks
    Rob Ross
    rross at mcs.anl.gov
    Thu May 29 10:50:28 CDT 2008
Thanks Ingo; I think that will do the trick for you. Sorry you ran
into this. -- Rob
On May 29, 2008, at 10:38 AM, Ingo Bojak wrote:
>> You've hit a problem in the combination of ROMIO and MPI
>> implementation. Can you tell us what MPI version you are using?
> I'm using the current MPICH2-1.0.7 both under Cygwin and on the Linux
> cluster.
>> In the mean time you may want to instead use a struct with an MPI_LB/
>> MPI_UB pair to extend your type, rather than using resize.
> OK, thanks. I will try if that works better.
> Cheers,
> Ingo
