[mpich-discuss] MPI_File_set_view Error: ADIOI_Count_contiguous_blocks
Ingo Bojak I.Bojak at science.ru.nl
Thu May 29 10:38:54 CDT 2008
> You've hit a problem in the combination of ROMIO and MPI
> implementation. Can you tell us what MPI version you are using?
I'm using the current MPICH2-1.0.7 both under Cygwin and on the Linux
cluster.
> In the mean time you may want to instead use a struct with an MPI_LB/
> MPI_UB pair to extend your type, rather than using resize.
OK, thanks. I will try if that works better.
Cheers,
Ingo
