[mpich-discuss] Trouble in getting the logging interface to work
    Dave Goodell
    goodell at mcs.anl.gov
    Thu Mar 20 15:56:23 CDT 2008
It's pretty hard to debug this issue via email.  However, you could
try running valgrind on your modified MPICH2 to see if any obvious
bugs pop out.  When you do, make sure that you configure with "--
enable-g=dbg,meminit" in order to avoid spurious warnings and to be
able to see stack traces.
-Dave
On Mar 19, 2008, at 1:05 PM, Krishna Chaitanya wrote:
> The problem seems to be with the communicator in MPI_Bcast() (/src/
> mpi/coll/bcast.c).
> The comm_ptr is initialized to NULL and after a call to
> MPID_Comm_get_ptr( comm, comm_ptr ); , the comm_ptr points to the
> communicator object which was created throught MPI_Init().
> However,  MPID_Comm_valid_ptr( comm_ptr, mpi_errno ) returns with a
> value other than MPI_SUCCESS.
> During some traces, it used to crash at this point itself. On some
> other traces, it used to go into the progress engine as I described
> in my previous mails.
> What could be the reason? Hope someone chips in. I havent been able
> to figure this out for sometime now.
> Krishna Chaitanya K
> On Wed, Mar 19, 2008 at 8:44 AM, Krishna Chaitanya
> <kris.c1986 at gmail.com> wrote:
> This might help :
> In the MPID_Comm structure, I have included the following line for
> the peruse place-holder :
>  struct mpich_peruse_handle_t** c_peruse_handles;
> And in the function, MPID_Init_thread(), i have the line
>  MPIR_Process.comm_world->c_peruse_handles = NULL;
>  when the rest of the members of the comm_world structure are being
> populated.
> Thanks,
> Krishna Chaitanya K
> On Wed, Mar 19, 2008 at 8:19 AM, Krishna Chaitanya
> Thanks for the help. I am facing an weird problem right now. To
> incorporate the PERUSE component, I have modified the communicator
> data structure to incude the PERUSE handles. The program executes
> as expected when compiled without the "mpe=mpilog" flag.When I
> compile it with the mpe component, the program gives this output :
> Fatal error in MPI_Bcast: Invalid communicator, error stack:
> MPI_Bcast(784): MPI_Bcast(buf=0x9260f98, count=1, MPI_INT, root=0,
> MPI_COMM_WORLD) failed
> MPI_Bcast(717): Invalid communicator
> On tracing further, I understood this :
> MPI_Init () (  log_mpi_core.c )
>  -- >  PMPI_Init ( the communicator object is created here )
>  -- >  MPE_Init_log ()
>         -- > CLOG_Local_init()
>               -- > CLOG_Buffer_init4write ()
>                     -- > CLOG_Preamble_env_init()
>                           -- >   MPI_Bcast ()  (bcast.c)
>                                   -- > MPIR_Bcast ()
>                                          -- >  MPIC_Recv ()  /
> MPIC_Send()
>                                          -- >  MPIC_Wait()
>                                       < Program crashes >
>      The MPIC_Wait function is invoking the progress engine, which
> works properly without the mpe component.
>       Even within the progress engine, MPIDU_Sock_wait() and
> MPIDI_CH3I_Progress_handle_sock_event() are executed a couple of
> times before the program crashes in the MPIDU_Socki_handle_read()
> or the MPIDU_Socki_handle_write() functions. ( The read() and the
> write() functions work two times, I think)
>      I am finding it very hard to reason why the program crashes
> with mpe. Could you please suggest where I need to look at to sort
> this issue out?
> Thanks,
> Krishna Chaitanya K
> On Wed, Mar 19, 2008 at 2:20 AM, Anthony Chan <chan at mcs.anl.gov>
> wrote:
> On Wed, 19 Mar 2008, Krishna Chaitanya wrote:
> > Hi,
> >          I tried configuring MPICH2 by doing :
> > ./configure --prefix=/home/kc/mpich-install/ --enable-mpe
> > --with-logging=SLOG  CC=gcc CFLAGS=-g   && make && make install
> >          It  flashed an error messaage saying :
> > onfigure: error: ./src/util/logging/SLOG does not exist.
> Configure aborted
> The --with-logging is for MPICH2's internal logging, not MPE's
> logging.
> As what you did below is fine is fine.
> >          After that, I tried :
> > ./configure --prefix=/home/kc/mpich-install/ --enable-mpe CC=gcc
> CFLAGS=-g
> >         The installation was normal, when I tried compiling an
> example
> > program by doing :
> > mpicc -mpilog -o sample  sample.c
> > cc1: error: unrecognized command line option "-mpilog"
> Do "mpicc -mpe=mpilog -o sample sample.c" instead.  For more details,
> see "mpicc -mpe=help" and see mpich2/src/mpe2/README.
> A.Chan
> >          Can anyone please tell me what needs to be done to use
> the SLOG
> > logging format?
> > Thanks,
> > Krishna Chaitanya K
> > In the middle of difficulty, lies opportunity
