[mpich-discuss] Trouble in getting the logging interface to work
    Krishna Chaitanya
    kris.c1986 at gmail.com
    Wed Mar 19 13:05:21 CDT 2008
The problem seems to be with the communicator in MPI_Bcast()
(/src/mpi/coll/bcast.c).
The comm_ptr is initialized to NULL and after a call to MPID_Comm_get_ptr(
comm, comm_ptr ); , the comm_ptr points to the communicator object which was
created throught MPI_Init(). However,  MPID_Comm_valid_ptr( comm_ptr,
mpi_errno ) returns with a value other than MPI_SUCCESS.
During some traces, it used to crash at this point itself. On some other
traces, it used to go into the progress engine as I described in my previous
mails.
What could be the reason? Hope someone chips in. I havent been able to
figure this out for sometime now.
Krishna Chaitanya K
On Wed, Mar 19, 2008 at 8:44 AM, Krishna Chaitanya <kris.c1986 at gmail.com>
wrote:
> This might help :
> In the MPID_Comm structure, I have included the following line for the
> peruse place-holder :
>  struct mpich_peruse_handle_t** c_peruse_handles;
> And in the function, MPID_Init_thread(), i have the line
>  MPIR_Process.comm_world->c_peruse_handles = NULL;
>  when the rest of the members of the comm_world structure are being
> populated.
> Thanks,
> Krishna Chaitanya K
> On Wed, Mar 19, 2008 at 8:19 AM, Krishna Chaitanya <kris.c1986 at gmail.com>
> wrote:
> > Thanks for the help. I am facing an weird problem right now. To
> > incorporate the PERUSE component, I have modified the communicator data
> > structure to incude the PERUSE handles. The program executes as expected
> > when compiled without the "mpe=mpilog" flag.When I compile it with the
> > mpe component, the program gives this output :
> > Fatal error in MPI_Bcast: Invalid communicator, error stack:
> > MPI_Bcast(784): MPI_Bcast(buf=0x9260f98, count=1, MPI_INT, root=0,
> > MPI_COMM_WORLD) failed
> > MPI_Bcast(717): Invalid communicator
> > On tracing further, I understood this :
> > MPI_Init () (  log_mpi_core.c )
> >  -- >  PMPI_Init ( the communicator object is created here )
> >  -- >  MPE_Init_log ()
> >         -- > CLOG_Local_init()
> >               -- > CLOG_Buffer_init4write ()
> >                     -- > CLOG_Preamble_env_init()
> >                           -- >   MPI_Bcast ()  (bcast.c)
> >                                   -- > MPIR_Bcast ()
> >                                          -- >  MPIC_Recv ()  /
> > MPIC_Send()
> >                                          -- >  MPIC_Wait()
> >                                       < Program crashes >
> >      The MPIC_Wait function is invoking the progress engine, which works
> > properly without the mpe component.
> >       Even within the progress engine, MPIDU_Sock_wait() and
> > MPIDI_CH3I_Progress_handle_sock_event() are executed a couple of times
> > before the program crashes in the MPIDU_Socki_handle_read() or the
> > MPIDU_Socki_handle_write() functions. ( The read() and the write() functions
> > work two times, I think)
> >      I am finding it very hard to reason why the program crashes with
> > mpe. Could you please suggest where I need to look at to sort this issue
> > out?
> > Thanks,
> > Krishna Chaitanya K
> > On Wed, Mar 19, 2008 at 2:20 AM, Anthony Chan <chan at mcs.anl.gov> wrote:
> > > On Wed, 19 Mar 2008, Krishna Chaitanya wrote:
> > > > Hi,
> > > >          I tried configuring MPICH2 by doing :
> > > > ./configure --prefix=/home/kc/mpich-install/ --enable-mpe
> > > > --with-logging=SLOG  CC=gcc CFLAGS=-g   && make && make install
> > > >          It  flashed an error messaage saying :
> > > > onfigure: error: ./src/util/logging/SLOG does not exist.  Configure
> > > aborted
> > > The --with-logging is for MPICH2's internal logging, not MPE's
> > > logging.
> > > As what you did below is fine is fine.
> > > >          After that, I tried :
> > > > ./configure --prefix=/home/kc/mpich-install/ --enable-mpe CC=gcc
> > > CFLAGS=-g
> > > >         The installation was normal, when I tried compiling an
> > > example
> > > > program by doing :
> > > > mpicc -mpilog -o sample  sample.c
> > > > cc1: error: unrecognized command line option "-mpilog"
> > > Do "mpicc -mpe=mpilog -o sample sample.c" instead.  For more details,
> > > see "mpicc -mpe=help" and see mpich2/src/mpe2/README.
> > > A.Chan
> > > >          Can anyone please tell me what needs to be done to use the
> > > SLOG
> > > > logging format?
> > > > Thanks,
> > > > Krishna Chaitanya K
> > > > In the middle of difficulty, lies opportunity
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080319/493e4dd1/attachment.htm>
