[mpich-discuss] Trouble in getting the logging interface to work
    Krishna Chaitanya
    kris.c1986 at gmail.com
    Fri Mar 21 06:59:20 CDT 2008
Well, the communicator object was getting deleted in the call to
MPIR_Comm_release ( invoked by MPID_Request_release()).. The inuse pointer
was being returned as 0.As a temporary fix,in MPI_ Init, I have set
ref_count paramenter for the comm object as 2. I shall trace through the
calls to see if it was getting decremented prior to MPID_Request_release().
Its is working for now and generating  the logfile in the ".clog2" format. I
executed the clogTOslog2 script and converted the format.
When I try loading the this log file to jumpshot, I get the following text
output :
GUI_LIBDIR is set. GUI_LIBDIR = /home/kc/mpich-install//lib
Java is version 1.4.2.
Starting the SLOG-2 Display Program .....
Jumpshot-4 setup file : /home/kc/.jumpshot4.conf
Initialize Parameters:
Y_AXIS_ROOT_LABEL = SLOG-2
INIT_SLOG2_LEVEL_READ = 4
AUTO_WINDOWS_LOCATION = true
SCREEN_HEIGHT_RATIO = 0.5
TIME_SCROLL_UNIT_RATIO = 0.01
Y_AXIS_ROOT_VISIBLE = true
ACTIVE_REFRESH = false
ROW_RESIZE_MODE = Row
BACKGROUND_COLOR = black
STATE_HEIGHT_FACTOR = 0.9
NESTING_HEIGHT_FACTOR = 0.8
ARROW_ANTIALIASING = default
MIN_WIDTH_TO_DRAG = 4
CLICK_RADIUS_TO_LINE = 3
LEFTCLICK_INSTANT_ZOOM = true
STATE_BORDER = ColorRaised
ARROW_HEAD_LENGTH = 10
ARROW_HEAD_WIDTH = 6
EVENT_BASE_WIDTH = 8
PREVIEW_STATE_DISPLAY = CumulativeExclusionRatio
PREVIEW_STATE_BORDER = ColorXOR
PREVIEW_STATE_BORDER_W = 3
PREVIEW_STATE_BORDER_H = 0
PREVIEW_STATE_LEGEND_H = 2
PREVIEW_ARROW_LOG_BASE = 5
SEARCH_ARROW_LENGTH = 20
SEARCH_FRAME_THICKNESS = 3
SEARCHED_OBJECT_ON_TOP = false
HISTOGRAM_ZERO_ORIGIN = true
SUMMARY_STATE_BORDER = ColorRaised
SUMMARY_ARROW_LOG_BASE = 5
LEGEND_PREVIEW_ORDER = true
LEGEND_TOPOLOGY_ORDER = true
The file block pointer to the Tree Directory is NOT initialized!, can't read
it.
         IS there any environment variable that needs to be initialsed?
Krishna Chaitanya K
On Thu, Mar 20, 2008 at 4:56 PM, Dave Goodell <goodell at mcs.anl.gov> wrote:
> It's pretty hard to debug this issue via email.  However, you could
> try running valgrind on your modified MPICH2 to see if any obvious
> bugs pop out.  When you do, make sure that you configure with "--
> enable-g=dbg,meminit" in order to avoid spurious warnings and to be
> able to see stack traces.
> -Dave
> On Mar 19, 2008, at 1:05 PM, Krishna Chaitanya wrote:
> > The problem seems to be with the communicator in MPI_Bcast() (/src/
> > mpi/coll/bcast.c).
> > The comm_ptr is initialized to NULL and after a call to
> > MPID_Comm_get_ptr( comm, comm_ptr ); , the comm_ptr points to the
> > communicator object which was created throught MPI_Init().
> > However,  MPID_Comm_valid_ptr( comm_ptr, mpi_errno ) returns with a
> > value other than MPI_SUCCESS.
> > During some traces, it used to crash at this point itself. On some
> > other traces, it used to go into the progress engine as I described
> > in my previous mails.
> > What could be the reason? Hope someone chips in. I havent been able
> > to figure this out for sometime now.
> > Krishna Chaitanya K
> > On Wed, Mar 19, 2008 at 8:44 AM, Krishna Chaitanya
> > <kris.c1986 at gmail.com> wrote:
> > This might help :
> > In the MPID_Comm structure, I have included the following line for
> > the peruse place-holder :
> >  struct mpich_peruse_handle_t** c_peruse_handles;
> > And in the function, MPID_Init_thread(), i have the line
> >  MPIR_Process.comm_world->c_peruse_handles = NULL;
> >  when the rest of the members of the comm_world structure are being
> > populated.
> > Thanks,
> > Krishna Chaitanya K
> > On Wed, Mar 19, 2008 at 8:19 AM, Krishna Chaitanya
> > Thanks for the help. I am facing an weird problem right now. To
> > incorporate the PERUSE component, I have modified the communicator
> > data structure to incude the PERUSE handles. The program executes
> > as expected when compiled without the "mpe=mpilog" flag.When I
> > compile it with the mpe component, the program gives this output :
> > Fatal error in MPI_Bcast: Invalid communicator, error stack:
> > MPI_Bcast(784): MPI_Bcast(buf=0x9260f98, count=1, MPI_INT, root=0,
> > MPI_COMM_WORLD) failed
> > MPI_Bcast(717): Invalid communicator
> > On tracing further, I understood this :
> > MPI_Init () (  log_mpi_core.c )
> >  -- >  PMPI_Init ( the communicator object is created here )
> >  -- >  MPE_Init_log ()
> >         -- > CLOG_Local_init()
> >               -- > CLOG_Buffer_init4write ()
> >                     -- > CLOG_Preamble_env_init()
> >                           -- >   MPI_Bcast ()  (bcast.c)
> >                                   -- > MPIR_Bcast ()
> >                                          -- >  MPIC_Recv ()  /
> > MPIC_Send()
> >                                          -- >  MPIC_Wait()
> >                                       < Program crashes >
> >      The MPIC_Wait function is invoking the progress engine, which
> > works properly without the mpe component.
> >       Even within the progress engine, MPIDU_Sock_wait() and
> > MPIDI_CH3I_Progress_handle_sock_event() are executed a couple of
> > times before the program crashes in the MPIDU_Socki_handle_read()
> > or the MPIDU_Socki_handle_write() functions. ( The read() and the
> > write() functions work two times, I think)
> >      I am finding it very hard to reason why the program crashes
> > with mpe. Could you please suggest where I need to look at to sort
> > this issue out?
> > Thanks,
> > Krishna Chaitanya K
> > On Wed, Mar 19, 2008 at 2:20 AM, Anthony Chan <chan at mcs.anl.gov>
> > wrote:
> > On Wed, 19 Mar 2008, Krishna Chaitanya wrote:
> > > Hi,
> > >          I tried configuring MPICH2 by doing :
> > > ./configure --prefix=/home/kc/mpich-install/ --enable-mpe
> > > --with-logging=SLOG  CC=gcc CFLAGS=-g   && make && make install
> > >          It  flashed an error messaage saying :
> > > onfigure: error: ./src/util/logging/SLOG does not exist.
> > Configure aborted
> > The --with-logging is for MPICH2's internal logging, not MPE's
> > logging.
> > As what you did below is fine is fine.
> > >          After that, I tried :
> > > ./configure --prefix=/home/kc/mpich-install/ --enable-mpe CC=gcc
> > CFLAGS=-g
> > >         The installation was normal, when I tried compiling an
> > example
> > > program by doing :
> > > mpicc -mpilog -o sample  sample.c
> > > cc1: error: unrecognized command line option "-mpilog"
> > Do "mpicc -mpe=mpilog -o sample sample.c" instead.  For more details,
> > see "mpicc -mpe=help" and see mpich2/src/mpe2/README.
> > A.Chan
> > >          Can anyone please tell me what needs to be done to use
> > the SLOG
> > > logging format?
> > > Thanks,
> > > Krishna Chaitanya K
> > > In the middle of difficulty, lies opportunity
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080321/b6c4864a/attachment.htm>
