[mpich-discuss] Trouble in getting the logging interface to work
Krishna Chaitanya
kris.c1986 at gmail.com
Wed Mar 19 07:44:08 CDT 2008
This might help :
In the MPID_Comm structure, I have included the following line for the
peruse place-holder :
struct mpich_peruse_handle_t** c_peruse_handles;
And in the function, MPID_Init_thread(), i have the line
MPIR_Process.comm_world->c_peruse_handles = NULL;
when the rest of the members of the comm_world structure are being
populated.
Krishna Chaitanya K
On Wed, Mar 19, 2008 at 8:19 AM, Krishna Chaitanya <kris.c1986 at gmail.com>
wrote:
> Thanks for the help. I am facing an weird problem right now. To
> incorporate the PERUSE component, I have modified the communicator data
> structure to incude the PERUSE handles. The program executes as expected
> when compiled without the "mpe=mpilog" flag.When I compile it with the mpe
> component, the program gives this output :
> Fatal error in MPI_Bcast: Invalid communicator, error stack:
> MPI_Bcast(784): MPI_Bcast(buf=0x9260f98, count=1, MPI_INT, root=0,
> MPI_COMM_WORLD) failed
> MPI_Bcast(717): Invalid communicator
> On tracing further, I understood this :
> MPI_Init () ( log_mpi_core.c )
> -- > PMPI_Init ( the communicator object is created here )
> -- > MPE_Init_log ()
> -- > CLOG_Local_init()
> -- > CLOG_Buffer_init4write ()
> -- > CLOG_Preamble_env_init()
> -- > MPI_Bcast () (bcast.c)
> -- > MPIR_Bcast ()
> -- > MPIC_Recv () / MPIC_Send()
> -- > MPIC_Wait()
> < Program crashes >
> The MPIC_Wait function is invoking the progress engine, which works
> properly without the mpe component.
> Even within the progress engine, MPIDU_Sock_wait() and
> MPIDI_CH3I_Progress_handle_sock_event() are executed a couple of times
> before the program crashes in the MPIDU_Socki_handle_read() or the
> MPIDU_Socki_handle_write() functions. ( The read() and the write() functions
> work two times, I think)
> I am finding it very hard to reason why the program crashes with mpe.
> Could you please suggest where I need to look at to sort this issue out?
> Thanks,
> Krishna Chaitanya K
> On Wed, Mar 19, 2008 at 2:20 AM, Anthony Chan <chan at mcs.anl.gov> wrote:
> > On Wed, 19 Mar 2008, Krishna Chaitanya wrote:
> > > Hi,
> > > I tried configuring MPICH2 by doing :
> > > ./configure --prefix=/home/kc/mpich-install/ --enable-mpe
> > > --with-logging=SLOG CC=gcc CFLAGS=-g && make && make install
> > > It flashed an error messaage saying :
> > > onfigure: error: ./src/util/logging/SLOG does not exist. Configure
> > aborted
> > The --with-logging is for MPICH2's internal logging, not MPE's logging.
> > As what you did below is fine is fine.
> > > After that, I tried :
> > > ./configure --prefix=/home/kc/mpich-install/ --enable-mpe CC=gcc
> > CFLAGS=-g
> > > The installation was normal, when I tried compiling an example
> > > program by doing :
> > > mpicc -mpilog -o sample sample.c
> > > cc1: error: unrecognized command line option "-mpilog"
> > Do "mpicc -mpe=mpilog -o sample sample.c" instead. For more details,
> > see "mpicc -mpe=help" and see mpich2/src/mpe2/README.
> > A.Chan
> > > Can anyone please tell me what needs to be done to use the
> > SLOG
> > > logging format?
> > > Thanks,
> > > Krishna Chaitanya K
> > > In the middle of difficulty, lies opportunity
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080319/295aa7f3/attachment.htm>
