[mpich-discuss] Windows & Name publishing
    Rob Ross
    rross at mcs.anl.gov
    Mon Mar 17 09:58:30 CDT 2008
Are you trying to start the client service under a separate mpiexec
invocation?
Rob
On Mar 17, 2008, at 9:48 AM, Andrea Galligani wrote:
> Hi,
> I'm writing a client/server application similar to the pman_vis
> sample. I would use the name publishing service
> to manage the port name. My problem is that the server registers the
> pair <port name, service name> without errors
> but on the client side the MPI_Lookup_name fails reporting an error
> code 0C01FF21 hex.
> Does somebody knows what is the cause?
> I'm using:
> Windows XP pro
> Visual Studio 2005
> MPICH2 v 1.0.6p1 (I compiled the source code)
> I start my server using the command
> mpiexec -channel mt -n 5 CmdServer.exe
> The application work well if I copy the port name manually.
> Thanks
> Andrea
