[mpich-discuss] Windows & Name publishing
    Andrea Galligani
    andrea.galligani at macstech.it
    Mon Mar 17 09:48:34 CDT 2008
I'm writing a client/server application similar to the pman_vis sample.
I would use the name publishing service
to manage the port name. My problem is that the server registers the
pair <port name, service name> without errors
but on the client side the MPI_Lookup_name fails reporting an error code
0C01FF21 hex.
Does somebody knows what is the cause?
I'm using:
Windows XP pro
Visual Studio 2005
MPICH2 v 1.0.6p1 (I compiled the source code)
I start my server using the command
mpiexec -channel mt -n 5 CmdServer.exe
The application work well if I copy the port name manually.
Thanks
Andrea
