[mpich-discuss] Windows & Name publishing
Andrea Galligani
andrea.galligani at macstech.it
Mon Mar 17 11:32:57 CDT 2008
Yes I tried to to start my client as a normal windows program and also
using the following command
mpiexec -localroot -n 1 GuiClient.exe
obtaining the same error code.
Andrea
Rob Ross ha scritto:
> Are you trying to start the client service under a separate mpiexec
> invocation?
> Rob
> On Mar 17, 2008, at 9:48 AM, Andrea Galligani wrote:
>> Hi,
>> I'm writing a client/server application similar to the pman_vis
>> sample. I would use the name publishing service
>> to manage the port name. My problem is that the server registers the
>> pair <port name, service name> without errors
>> but on the client side the MPI_Lookup_name fails reporting an error
>> code 0C01FF21 hex.
>> Does somebody knows what is the cause?
>> I'm using:
>> Windows XP pro
>> Visual Studio 2005
>> MPICH2 v 1.0.6p1 (I compiled the source code)
>> I start my server using the command
>> mpiexec -channel mt -n 5 CmdServer.exe
>> The application work well if I copy the port name manually.
>> Thanks
>> Andrea
