[mpich-discuss] Problems with multiple calls to MPI_Reduce?
Michael Ahlmann
mahlmann at ucdavis.edu
Fri Jun 27 09:19:14 CDT 2008
Elliot,
I had a similar problem, and it was caused by using non-unique tags
for my calls.
-Michael
Elliot Parkin wrote:
> Hello everyone,
> I've ran into some difficulties using MPI_Reduce. It seems that after
> it has been called some of the parameters in the code get set to
> bizarre values. Also, if I call MPI_Reduce consecutively (to fill an
> array with the maximum values across the processes) it doesn't appear
> to work the third time and sets all values of the array to zero. Has
> anybody else had this problem, and if so is there any way to
> explain/fix this?
> Cheers,
> Elliot Parkin.
> This message was sent using IMP, the Internet Messaging Program.
