[mpich-discuss] Problems with multiple calls to MPI_Reduce?
Rajeev Thakur thakur at mcs.anl.gov
Fri Jun 27 10:54:57 CDT 2008
Can you send us a small code fragment?
Rajeev
> -----Original Message-----
> From: owner-mpich-discuss at mcs.anl.gov
> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Elliot Parkin
> Sent: Friday, June 27, 2008 6:28 AM
> To: mpich-discuss at mcs.anl.gov
> Subject: [mpich-discuss] Problems with multiple calls to MPI_Reduce?
> Hello everyone,
> I've ran into some difficulties using MPI_Reduce. It seems
> that after
> it has been called some of the parameters in the code get set to
> bizarre values. Also, if I call MPI_Reduce consecutively (to fill an
> array with the maximum values across the processes) it
> doesn't appear
> to work the third time and sets all values of the array to zero. Has
> anybody else had this problem, and if so is there any way to
> explain/fix this?
> Cheers,
> Elliot Parkin.
> This message was sent using IMP, the Internet Messaging Program.
