[mpich-discuss] Problems with multiple calls to MPI_Reduce?
Elliot Parkin phy1erp at leeds.ac.uk
Fri Jun 27 06:28:13 CDT 2008
Hello everyone,
I've ran into some difficulties using MPI_Reduce. It seems that after
it has been called some of the parameters in the code get set to
bizarre values. Also, if I call MPI_Reduce consecutively (to fill an
array with the maximum values across the processes) it doesn't appear
to work the third time and sets all values of the array to zero. Has
anybody else had this problem, and if so is there any way to
explain/fix this?
Cheers,
Elliot Parkin.
This message was sent using IMP, the Internet Messaging Program.
