[mpich-discuss] building 32 bit shmem on 64 bit linux system
Rajeev Thakur
thakur at mcs.anl.gov
Thu Jun 26 09:46:42 CDT 2008
It must be the mpirun then. Make sure you use the mpirun from the same
build. Give the full path if necessary.
Rajeev
> -----Original Message-----
> From: owner-mpich-discuss at mcs.anl.gov
> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Daniel
> Fetchinson
> Sent: Thursday, June 26, 2008 1:25 AM
> To: mpich-discuss at mcs.anl.gov
> Subject: Re: [mpich-discuss] building 32 bit shmem on 64 bit
> linux system
> > Did you recompile the program? Make sure you use the mpicc
> from this
> > build and not some other mpicc from another directory. Give
> the full
> > path if necessary.
> > Rajeev
> Yes, I did recompile the program using mpicc from the newly
> built mpi library. Actually, there is only one mpicc on the
> whole machine.
> Cheers,
> Daniel
> >> Actually, I spoke a bit too soon. Configure, make, make
> install all
> >> work but the code still doesn't run, saying:
> >> 0 - MPI_INIT : MPIRUN chose the wrong device ch_shmem;
> program needs
> >> device ch_p4
> >> /home/fetchinson/mpi32shmem/bin/mpirun.ch_shmem: line 91: 17761
> >> Segmentation fault /home/fetchinson/test "testinput"
> >> The exact same code runs on another machine where someone else
> >> installed a 32-bit shmem mpich1 library, I'm trying to do
> the same on
> >> a different machine now. It's an intel quad core so I suppose the
> >> shmem device should work. The configure options I used for
> compiling
> >> are
> >> export CC='gcc -m32'
> >> export F77='g77 -m32'
> >> ./configure --with-device=ch_shmem
> >> Do I need to specify the --with-arch option? Going through
> the list
> >> of available --with-arch options I'm not sure what I need for an
> >> Intel(R)
> >> Core(TM)2 Quad CPU Q6600 @ 2.40GHz.
> >> What am I doing wrong?
> >> Cheers,
> >> Daniel
> >> > Thanks Anthony, that worked!
> >> > Concerning MPICH2: I'm not in a position to change the
> >> communication
> >> > routines in the code I use so this would only be an option
> >> if MPICH2
> >> > is fully backward compatible with MPICH1. Is this the case?
> >> Can I just
> >> > start using MPICH2 without changing anything in the code if
> >> it works
> >> > with MPICH1?
> >> > Cheers,
> >> > Daniel
> >> >> Since you are using MPICH-1, you can try setting CC, F77 and F90
> >> >> CC="gcc -m32"
> >> >> F77="g77 -m32"
> >> >> BTW, can you use MPICH2 instead ? We have shifted all our
> >> >> development effort to MPICH2 which is more robust than
> >> MPICH-1. If
> >> >> you are using MPICH2, setting CFLAGS and FFLAGS should
> >> work, and you
> >> >> can use nemesis which shared memory for intranode communication.
> >> >> A.Chan
> >> >> ----- "Daniel Fetchinson" <fetchinson at googlemail.com> wrote:
> >> >>> Hi folks,
> >> >>> I'd like to build the 32-bit shmem mpi library because
> >> the code I'll
> >> >>> use with mpi only works in 32-bit because of some
> 32-bit specific
> >> >>> assembly code. The machine is a 64-bit machine with a
> >> 64-bit linux
> >> >>> distribution (suse).
> >> >>> I tried configuring mpich-1.2.7p1 in a number of ways:
> >> >>> ./configure --with-device=ch_shmem ./configure
> --with-arch=LINUX
> >> >>> --with-arch=LINUX32 --with-device=ch_shmem ./configure
> >> >>> --with-arch=i386 --with-device=ch_shmem
> >> >>> with and without setting the following environment
> variables (in
> >> >>> bash):
> >> >>> export CFLAGS=-m32
> >> >>> export FFLAGS=-m32
> >> >>> Configuring went all right but none of the above
> >> combinations worked
> >> >>> with 'make' unfortunately :( The error in 'make' is
> the following:
> >> >>> /home/fetchinson/mpich-1.2.7p1/bin/mpicc -o overtake
> overtake.o
> >> >>> test.o
> >> /usr/lib64/gcc/x86_64-suse-linux/4.2.1/../../../../x86_64-suse
> >> -linux/bin/ld:
> >> >>> skipping incompatible
> >> /home/fetchinson/mpich-1.2.7p1/lib/libmpich.a
> >> >>> when searching for -lmpich
> >> -linux/bin/ld:
> >> >>> cannot find -lmpich
> >> >>> collect2: ld returned 1 exit status
> >> >>> make[4]: *** [overtake] Error 1
> >> >>> make[3]: [linktest1] Error 2 (ignored) Could not link
> a C program
> >> >>> with MPI libraries
> >> >>> make[3]: *** [linktest1] Error 1
> >> >>> make[2]: *** [linktest] Error 2
> >> >>> make[1]: *** [mpi-lib-test] Error 2
> >> >>> make: *** [mpi] Error 2
> >> >>> Which makes me believe that I was not able to convince the
> >> >>> compiler/linker/etc that I really want everything in 32-bit.
> >> >>> What would be the correct way of compiling the whole mpi
> >> library to
> >> >>> 32-bit?
> >> >>> Cheers,
> >> >>> Daniel
> >> > Psss, psss, put it down! - http://www.cafepress.com/putitdown
