[mpich-discuss] building 32 bit shmem on 64 bit linux system
Daniel Fetchinson fetchinson at googlemail.com
Thu Jun 26 10:23:28 CDT 2008
> It must be the mpirun then. Make sure you use the mpirun from the same
> build. Give the full path if necessary.
> Rajeev
Thanks, but there is only one installation of mpi on the machine and
that installation is the one I keep compiling. So even if it wanted to
execute the wrong mpicc/mpirun/etc it couldn't because there is only 1
copy at any given time.
Nevertheless I recompiled now mpi as well as my program and still I
get the same error:
0 - MPI_INIT : MPIRUN chose the wrong device ch_shmem; program needs
device ch_p4
/home/fetchinson/mpich32shmem/bin/mpirun.ch_shmem: line 91: 21976
Segmentation fault      /home/fetchinson/test "testinput"
Any ideas?
Daniel
>> > Did you recompile the program? Make sure you use the mpicc
>> from this
>> > build and not some other mpicc from another directory. Give
>> the full
>> > path if necessary.
>> > Rajeev
>> Yes, I did recompile the program using mpicc from the newly
>> built mpi library. Actually, there is only one mpicc on the
>> whole machine.
>> Cheers,
>> Daniel
>> >> Actually, I spoke a bit too soon. Configure, make, make
>> install all
>> >> work but the code still doesn't run, saying:
>> program needs
>> >> device ch_p4
>> >> /home/fetchinson/mpi32shmem/bin/mpirun.ch_shmem: line 91: 17761
>> >> The exact same code runs on another machine where someone else
>> >> installed a 32-bit shmem mpich1 library, I'm trying to do
>> the same on
>> >> a different machine now. It's an intel quad core so I suppose the
>> >> shmem device should work. The configure options I used for
>> compiling
>> >> are
>> >> export CC='gcc -m32'
>> >> export F77='g77 -m32'
>> >> ./configure  --with-device=ch_shmem
>> >> Do I need to specify the --with-arch option? Going through
>> the list
>> >> of available --with-arch options I'm not sure what I need for an
>> >> Intel(R)
>> >> Core(TM)2 Quad CPU Q6600 @ 2.40GHz.
>> >> What am I doing wrong?
>> >> Cheers,
>> >> Daniel
>> >> > Thanks Anthony, that worked!
>> >> > Concerning MPICH2: I'm not in a position to change the
>> >> communication
>> >> > routines in the code  I use so this would only be an option
>> >> if MPICH2
>> >> > is fully backward compatible with MPICH1. Is this the case?
>> >> Can I just
>> >> > start using MPICH2 without changing anything in the code if
>> >> it works
>> >> > with MPICH1?
>> >> > Cheers,
>> >> > Daniel
>> >> >> Since you are using MPICH-1, you can try setting CC, F77 and F90
>> >> >> CC="gcc -m32"
>> >> >> F77="g77 -m32"
>> >> >> BTW, can you use MPICH2 instead ?  We have shifted all our
>> >> >> development effort to MPICH2 which is more robust than
>> >> MPICH-1.  If
>> >> >> you are using MPICH2, setting CFLAGS and FFLAGS should
>> >> work, and you
>> >> >> can use nemesis which shared memory for intranode communication.
>> >> >> A.Chan
>> >> >> ----- "Daniel Fetchinson" <fetchinson at googlemail.com> wrote:
>> >> >>> Hi folks,
>> >> >>> I'd like to build the 32-bit shmem mpi library because
>> >> the code I'll
>> >> >>> use with mpi only works in 32-bit because of some
>> 32-bit specific
>> >> >>> assembly code. The machine is a 64-bit machine with a
>> >> 64-bit linux
>> >> >>> distribution (suse).
>> >> >>> I tried configuring mpich-1.2.7p1 in a number of ways:
>> >> >>> ./configure --with-device=ch_shmem ./configure
>> --with-arch=LINUX
>> >> >>> --with-arch=LINUX32 --with-device=ch_shmem ./configure
>> >> >>> --with-arch=i386 --with-device=ch_shmem
>> >> >>> with and without setting the following environment
>> variables (in
>> >> >>> bash):
>> >> >>> export CFLAGS=-m32
>> >> >>> export FFLAGS=-m32
>> >> >>> Configuring went all right but none of the above
>> >> combinations worked
>> >> >>> with 'make' unfortunately :( The error in 'make' is
>> the following:
>> >> >>> /home/fetchinson/mpich-1.2.7p1/bin/mpicc  -o overtake
>> overtake.o
>> >> >>> test.o
>> >> /usr/lib64/gcc/x86_64-suse-linux/4.2.1/../../../../x86_64-suse
>> >> -linux/bin/ld:
>> >> >>> skipping incompatible
>> >> /home/fetchinson/mpich-1.2.7p1/lib/libmpich.a
>> >> >>> when searching for -lmpich
>> >> -linux/bin/ld:
>> >> >>> cannot find -lmpich
>> >> >>> collect2: ld returned 1 exit status
>> >> >>> make[4]: *** [overtake] Error 1
>> >> >>> make[3]: [linktest1] Error 2 (ignored) Could not link
>> a C program
>> >> >>> with MPI libraries
>> >> >>> make[3]: *** [linktest1] Error 1
>> >> >>> make[2]: *** [linktest] Error 2
>> >> >>> make[1]: *** [mpi-lib-test] Error 2
>> >> >>> make: *** [mpi] Error 2
>> >> >>> Which makes me believe that I was not able to convince the
>> >> >>> compiler/linker/etc that I really want everything in 32-bit.
>> >> >>> What would be the correct way of compiling the whole mpi
>> >> library to
>> >> >>> 32-bit?
>> >> >>> Cheers,
>> >> >>> Daniel
>> >> > Psss, psss, put it down! - http://www.cafepress.com/putitdown
