[mpich-discuss] building 32 bit shmem on 64 bit linux system
Daniel Fetchinson
fetchinson at googlemail.com
Thu Jun 26 01:24:47 CDT 2008
> Did you recompile the program? Make sure you use the mpicc from this build
> and not some other mpicc from another directory. Give the full path if
> necessary.
> Rajeev
Yes, I did recompile the program using mpicc from the newly built mpi
library. Actually, there is only one mpicc on the whole machine.
Cheers,
Daniel
>> Actually, I spoke a bit too soon. Configure, make, make
>> install all work but the code still doesn't run, saying:
>> 0 - MPI_INIT : MPIRUN chose the wrong device ch_shmem;
>> program needs device ch_p4
>> /home/fetchinson/mpi32shmem/bin/mpirun.ch_shmem: line 91: 17761
>> Segmentation fault /home/fetchinson/test "testinput"
>> The exact same code runs on another machine where someone
>> else installed a 32-bit shmem mpich1 library, I'm trying to
>> do the same on a different machine now. It's an intel quad
>> core so I suppose the shmem device should work. The configure
>> options I used for compiling are
>> export CC='gcc -m32'
>> export F77='g77 -m32'
>> ./configure --with-device=ch_shmem
>> Do I need to specify the --with-arch option? Going through
>> the list of available --with-arch options I'm not sure what I
>> need for an Intel(R)
>> Core(TM)2 Quad CPU Q6600 @ 2.40GHz.
>> What am I doing wrong?
>> Cheers,
>> Daniel
>> > Thanks Anthony, that worked!
>> > Concerning MPICH2: I'm not in a position to change the
>> communication
>> > routines in the code I use so this would only be an option
>> if MPICH2
>> > is fully backward compatible with MPICH1. Is this the case?
>> Can I just
>> > start using MPICH2 without changing anything in the code if
>> it works
>> > with MPICH1?
>> > Cheers,
>> > Daniel
>> >> Since you are using MPICH-1, you can try setting CC, F77 and F90
>> >> CC="gcc -m32"
>> >> F77="g77 -m32"
>> >> BTW, can you use MPICH2 instead ? We have shifted all our
>> >> development effort to MPICH2 which is more robust than
>> MPICH-1. If
>> >> you are using MPICH2, setting CFLAGS and FFLAGS should
>> work, and you
>> >> can use nemesis which shared memory for intranode communication.
>> >> A.Chan
>> >> ----- "Daniel Fetchinson" <fetchinson at googlemail.com> wrote:
>> >>> Hi folks,
>> >>> I'd like to build the 32-bit shmem mpi library because
>> the code I'll
>> >>> use with mpi only works in 32-bit because of some 32-bit specific
>> >>> assembly code. The machine is a 64-bit machine with a
>> 64-bit linux
>> >>> distribution (suse).
>> >>> I tried configuring mpich-1.2.7p1 in a number of ways:
>> >>> ./configure --with-arch=LINUX --with-device=ch_shmem ./configure
>> >>> --with-arch=LINUX32 --with-device=ch_shmem ./configure
>> >>> --with-arch=i386 --with-device=ch_shmem
>> >>> with and without setting the following environment variables (in
>> >>> bash):
>> >>> export CFLAGS=-m32
>> >>> export FFLAGS=-m32
>> >>> Configuring went all right but none of the above
>> combinations worked
>> >>> with 'make' unfortunately :( The error in 'make' is the following:
>> >>> /home/fetchinson/mpich-1.2.7p1/bin/mpicc -o overtake overtake.o
>> >>> test.o
>> /usr/lib64/gcc/x86_64-suse-linux/4.2.1/../../../../x86_64-suse
>> -linux/bin/ld:
>> >>> skipping incompatible
>> /home/fetchinson/mpich-1.2.7p1/lib/libmpich.a
>> >>> when searching for -lmpich
>> -linux/bin/ld:
>> >>> cannot find -lmpich
>> >>> collect2: ld returned 1 exit status
>> >>> make[4]: *** [overtake] Error 1
>> >>> make[3]: [linktest1] Error 2 (ignored) Could not link a C program
>> >>> with MPI libraries
>> >>> make[3]: *** [linktest1] Error 1
>> >>> make[2]: *** [linktest] Error 2
>> >>> make[1]: *** [mpi-lib-test] Error 2
>> >>> make: *** [mpi] Error 2
>> >>> Which makes me believe that I was not able to convince the
>> >>> compiler/linker/etc that I really want everything in 32-bit.
>> >>> What would be the correct way of compiling the whole mpi
>> library to
>> >>> 32-bit?
>> >>> Cheers,
>> >>> Daniel
>> > Psss, psss, put it down! - http://www.cafepress.com/putitdown
