[mpich-discuss] MPICH2 error mpdboot
Rajeev Thakur
thakur at mcs.anl.gov
Tue Jul 8 08:12:54 CDT 2008
Probably something not right with the networking configuration on the
machines. To debug the problem, you can use the mpdcheck utility as
described in the installation guide (all steps).
Rajeev
> -----Original Message-----
> From: owner-mpich-discuss at mcs.anl.gov
> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Francisco Pastor
> Sent: Tuesday, July 08, 2008 6:50 AM
> To: mpich-discuss at mcs.anl.gov
> Subject: [mpich-discuss] MPICH2 error mpdboot
> Hi everyone
> I'm trying to set up a linux cluster that will use mpich2. After
> succesfully installing I go on through the check tests and
> get an error
> with mpdboot:
> /meteo at boira:~$ mpdboot -n 2 -f mpd.hosts
> mpdboot_boira (handle_mpd_output 406): from mpd on boira2,
> invalid port
> info:
> no_port/
> where boira and boira2 are two of the cluster nodes. MPICH2
> is exported
> on all the nodes, ssh is properly set up.
> I've tried googling but after reading a lot of messages about this
> problem couldn't find a solution.
> Any idea? what am I missing?
> Thanks in advance
> Francisco Pastor
> Meteorology department
> Fundación CEAM
> paco at ceam.es
> http://www.ceam.es/ceamet - http://www.ceam.es
> Parque Tecnologico, C/ Charles R. Darwin, 14
> 46980 PATERNA (Valencia), Spain
> Tlf. 96 131 82 27 - Fax. 96 131 81 90
> Usuario Linux registrado: 363952
