[mpich-discuss] MPICH2 error mpdboot -- SOLVED
    Francisco Pastor
    paco at ceam.es
    Wed Jul  9 06:57:21 CDT 2008
Thanks Rajeev for your suggestion
Running mpdcheck I found a problem regarding host IP's. There was a line
in /etc/hosts causing the problem, this line came from the Ubuntu 8.04
installation.
I had to comment the following line in /etc/hosts
#127.0.1.1 boira
and then I could succesfully run the MPICH2 tests and examples, namely
cpi as stated in the documentation.
Thanks again, hope it will help someone someday
Rajeev Thakur escribió:
> Probably something not right with the networking configuration on the
> machines. To debug the problem, you can use the mpdcheck utility as
> described in the installation guide (all steps).
> Rajeev
>> -----Original Message-----
>> From: owner-mpich-discuss at mcs.anl.gov
>> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Francisco Pastor
>> Sent: Tuesday, July 08, 2008 6:50 AM
>> To: mpich-discuss at mcs.anl.gov
>> Subject: [mpich-discuss] MPICH2 error mpdboot
>> Hi everyone
>> I'm trying to set up a linux cluster that will use mpich2. After
>> succesfully installing I go on through the check tests and
>> get an error
>> with mpdboot:
>> /meteo at boira:~$ mpdboot -n 2 -f mpd.hosts
>> mpdboot_boira (handle_mpd_output 406): from mpd on boira2,
>> invalid port
>> info:
>> no_port/
>> where boira and boira2 are two of the cluster nodes. MPICH2
>> is exported
>> on all the nodes, ssh is properly set up.
>> I've tried googling but after reading a lot of messages about this
>> problem couldn't find a solution.
>> Any idea? what am I missing?
>> Thanks in advance
>> Francisco Pastor
>> Meteorology department
>> Fundación CEAM
>> paco at ceam.es
>> http://www.ceam.es/ceamet - http://www.ceam.es
>> Parque Tecnologico, C/ Charles R. Darwin, 14
>> 46980 PATERNA (Valencia), Spain
>> Tlf. 96 131 82 27 - Fax. 96 131 81 90
>> Usuario Linux registrado: 363952
Francisco Pastor
Fundación CEAM
paco at ceam.es
