[MPICH] mpich2: smpd phrase missing? - don't share config file across PMs
    Stefan Becuwe
    stefan.becuwe at ua.ac.be
    Mon Jan 21 16:01:21 CST 2008
>  Are you sharing the smpd configuration file (by default ~/.smpd) across
> multiple smpd daemons ? Each smpd daemon should have its own configuration
> file (Only smpd root daemons modify the configuration file. Currently there
> is no locking mechanism implemented on unix systems to prevent multiple smpd
> root daemons from modifying the config file at the same time.).
Thanks for your advice.  Looking into "mpiexec -help2", I've tried the
options "-smpdfile a_copy_of_my_smpd_file" and "-noprompt" (separately)
... without success.  I still get:
"Please specify an authentication passphrase for this smpd: Would you like
to save this passphrase in '...'?
I guess I must be overlooking something...
Best regards
Stefan
